RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - DJEvoix - 10-05-2021
(04-11-2021, 06:06 PM)blueabyss Wrote: Thank you Peson great job.
In version 03/21, I inserted the missing actab in PKW (I took 7/2014 here) and then the message appears, see the picture.
I confirm no - not to implement - and everything continues - without defects.
The error is when entering through Xentry.
When entering via DAS - the error is the same - the fix is to run Xentry
How to remove this message - is it a solution?
Hi how you solve it
Ahoj, jak jsi to vyřešil, vidím CZ jazyk.
Řeším das a nefunguje mi Kdyztak pm
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - stimix - 10-12-2021
hi everyone have eror  help pls
RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - irfan2 - 11-06-2021
(09-14-2021, 12:04 AM)MMdoc2 Wrote:
(07-27-2016, 04:16 PM)pesona Wrote: Today i go to my friend to test this offline programming myself.
W204 and W211. Tested and it works.
Now, i need your help mates.
1. I was ask by a member here that he stumbled with release code and test digit 2, like this:
where do you get this numbers?
i think i know how to bypass it if i connect with the car and stumble with that.
but i need to know, if you don't bypass these numbers, where and how do you get this number from?
2. am i safe if don't connect battery charger?
offline programming commercial vehicles, wil begin after switch engine and start OFF. That's why i have peace in mind and don't need battery charger. for pkw, i read that the fan will on hardly etc etc..
i will continue with F3. but before that i need the information please.
Can somebody help me with test digit 2 code for to perform a software update of ETC  vgsnag2 in my car using DAS offline.. screen print attached. Can't found any solutions around
I also need help with this. what calculator is used for this?
RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - TKS12 - 11-07-2021
(11-06-2021, 10:28 PM)irfan2 Wrote:
(09-14-2021, 12:04 AM)MMdoc2 Wrote: Hallo Pesano question can you ofline program keys FBS4   ? and muss we have spezial keys or the old FBS3 is ok thanks in advance  \tks12
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 11-07-2021
sorry, i don't know mate.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - hofmax - 11-11-2021
Hey guys,
has anyone experienced the issue in the attachment and does anyone know how to solve it?
I am using XPT 2021.06 with genuine Tactrix Openport 2.0 trying to retrofit code 345 on 245.207.
I noticed that ver 2.5 has 3 different FM_Main.cnt files while ver 2 has only one. Is there a reason for that? The error occurs with ver 2 and ver 2.5
Thanks!
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Mark_B - 11-15-2021
Hi, I have been looking but not sure if I've missed them, apologies if I have. But is there any SDflash files for 2007 cars?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Denizli20 - 02-08-2022
Meal everyone
I have a problem that I haven't been able to solve until now. If I want to update my comand NTG3, DAS wants me to insert the CD Telematics, I tried it with a virtual drive and it didn't work. I don't know what to try I burned the CD that was on DAS with the number onto a CD and put it in the comand didn't work eithe
thanks to everyone who helps me with this problem.
Kind regards
Denizli20
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - revers81 - 03-31-2022
(04-01-2018, 09:19 PM)Tiqr Wrote:
(04-01-2018, 07:04 PM)pesona Wrote: @Tiqr look at the first post. there is a link to sdflash collections from 10-2008 up to 2017 in the bottom or you can try to download from my mini sdflash at the first post too.
Thanks for fast response @pesona. I download and mount SDflash disk to drive.
Now i get this error.
here my information.
Windows 7 x86
Xentry 07/2017
i put all fix.
Thanks.
Hi
as you solved the problem i have the same
