RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016+2017+2018 - revers81 - 04-02-2022
(03-31-2022, 06:11 PM)revers81 Wrote:
(04-01-2018, 09:19 PM)Tiqr Wrote:
(04-01-2018, 07:04 PM)pesona Wrote: @Tiqr look at the first post. there is a link to sdflash collections from 10-2008 up to 2017 in the bottom or you can try to download from my mini sdflash at the first post too.
Thanks for fast response @pesona. I download and mount SDflash disk to drive.
Now i get this error.
here my information.
Windows 7 x86
Xentry 07/2017
i put all fix.
Thanks.
Hi
as you solved the problem i have the same
can someone help to solve this problem
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - Kakabasa - 04-04-2022
Where to find rev 2.5 release i see only you have 2.0?
Wich one to use for xentry xpt 2022.03
For offline das programming?
DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - emcek - 04-07-2022
Browse through the thread, it's there
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - revers81 - 04-07-2022
I looked through the thread but I did not find a solution
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - revers81 - 04-15-2022
no one knows how to fix it
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - cardiy - 04-17-2022
(06-21-2021, 07:56 AM)pesona Wrote: yes, sure it is for das vehicles only and w204 in das standalone.
Can we use offline programming in DAS for w166?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - bumer_m3 - 04-27-2022
in the 1. Post i find
Release: 2015 - 07/2019. But the link to the download is: "TRANSP Offline Programming 2015 to 09-2016 ver 1.0.txt" can i use this, if i have DAS2018?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 04-28-2022
(04-27-2022, 09:26 PM)bumer_m3 Wrote: in the 1. Post i find
as far as i remember, it is okay. but it is wise to backup your original flash folder first before you play with it.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - shewush - 05-04-2022
(04-04-2022, 12:46 PM)Kakabasa Wrote: Where to find rev 2.5 release i see only you have 2.0?
https://mhhauto.com/Thread-DAS-PKW-SMART-Transporter-Offline-Programming-2014-2015-2020?pid=1973030#pid1973030
