RE: Support thread for FullFixbySamik paid version - Cranetech_BR - 08-15-2026
Hello, I've discovered the cause of my DAS error. DAS is looking for these files:
LKW\Menues\mnlkwaut.s
BharatBenz\menues\MNDICV.s
imo\menues\MNIMO.s
but they don't exist in my installation.
I checked all the MSI files for S_DTDPT_26.7.3 and these files are not included.
The lower-level DAS trees for ADM2, FR, and MR are present, so it seems only the main/legacy menu structure is missing.
Do you know which older DAS package, add-on, or component provides these files? Can you help me restore the correct and compatible LKW/IMO /Internal error: SGML file LKWMenues mnlkwaut.s not found... Internal error: SGML file BharatBenz\menues\MNDICV.s not found...Internal error: SGML file BharatBenz\menues\MNDICV.s not found... and othersDAS menu files without mixing versions?
RE: Support thread for FullFixbySamik paid version - Wetwiki - 08-15-2026
(08-15-2026, 09:37 PM)Cranetech_BR Wrote: Hello, I've discovered the cause of my DAS error. DAS is looking for these files:
imo\menues\MNIMO.s
Try @Pesona DAS Medicine
(08-15-2026, 09:36 PM)Wetwiki Wrote:
(08-15-2026, 09:21 PM)Sam!k Wrote:
(08-15-2026, 09:13 PM)Wetwiki Wrote: found a problem when testing paid fix in SDconnect C4 adding, the problem is it works fine with XENTRY/Daimler with new trucks but when using DAS (old trucks) always gives no connections error !
tried the follwing:
- back to VCI then to SDconnect again from SDconnect to VCI switcher
- reinstalling the SDconnect kit from outer source
note :
- FIX versions used >>> 9.0.8, 9.1.0,  9.1.6, 9.1.3, 9.1.4 & 9.1.6
- the appears on daimler truck versions >>>>  1-2026, 3-2026 & 7-2026
- on xentry >> cars >>> not tested
- IP address was checked
- C4 MUX tested on other old Xentry versions (which have SDconnect already) & works fine
- testing done on many old trucks which using DAS
- attached PIC for no response
It should give that error and immediately after that should come firewall access request, need to allow and rety and it will work.
Don't disable firewall, it should be factory settings.
firewall not disabled
no firewall requests comes
tested many times
Note :
windows defender KILLED at all
waiting !!
RE: Support thread for FullFixbySamik paid version - Wetwiki - 08-17-2026
no response !
fix became not available on Ur landing page !
RE: Support thread for FullFixbySamik paid version - gcs190 - 08-17-2026
Both 01 and 04 and 07.2026 of trucks work perfectly in the truck and SD Connect versions if their operability is restored properly.
(08-17-2026, 07:18 PM)gcs190 Wrote: Both 01 and 04 and 07.2026 of trucks work perfectly in the truck and SD Connect versions if their operability is restored properly.
its matter of FIX itself,
not how to Call or how to fix SDc ! (easy way !!)
RE: Support thread for FullFixbySamik paid version - Sam!k - 08-17-2026
(08-15-2026, 09:36 PM)Wetwiki Wrote: firewall not disabled
tested many times
Note :
So should come!
If didn't come, then something wrong in system, in firewall.
RE: Support thread for FullFixbySamik paid version - Sam!k - 08-18-2026
tested many times
Note :
For be sure, i just installed clean S_DTPID_26.7.4 with latest version of fix, tested run DAS from Xentry and from standalone.
In both cases, firewall asked access.
RE: Support thread for FullFixbySamik paid version - Wetwiki - 08-20-2026
tested many times
Note :
tested on same version, firewall PoP-UPed in DAS from Daimler only.
standalone DAS no firewall PoP-Up & connection failed !!
Note :
- Win 10
- fix version v9.1.6
RE: Support thread for FullFixbySamik paid version - Sam!k - 08-20-2026
I don't remember that i something changed ij that way from v9.1.6, so don't think problem in old version anyway, don't understand why install old version, when there's a new version and working activation key.
Probably, i think you do all tests in the same system, which is not so good.
Or, with older version of fix, then 9.1.6!
