RE: Support thread for FullFixbySamik paid version - Rabih AMG - 09-21-2026
Hi. Everything was working good I tried working on W206 with xentry all good but after I used DAS on a W203 and then tried to open xentry it doesn’t open and gives error [2221-1] XENTRY could not be started. What could be the issue?
RE: Support thread for FullFixbySamik paid version - Sam!k - 09-21-2026
(09-21-2026, 05:13 PM)Rabih AMG Wrote: Hi. Everything was working good I tried working on W206 with xentry all good but after I used DAS on a W203 and then tried to open xentry it doesn’t open and gives error [2221-1] XENTRY could not be started. What could be the issue?
There was something else!
Just after running DAS can't be such problem.
Nothing at all. What should I do next?
RE: Support thread for FullFixbySamik paid version - Wetwiki - 09-22-2026
Ur Add-On Updates is running !
- run Add-On Blocker >>> Block
- reRun Fix again
All Done
RE: Support thread for FullFixbySamik paid version - Sam!k - 09-22-2026
(09-21-2026, 06:08 PM)Rabih AMG Wrote: Nothing at all. What should I do next?
Maybe in error message, there's something else, some file, for example?
Make a screenshot.
RE: Support thread for FullFixbySamik paid version - luki03 - 09-22-2026
Make a screenshot.
after the addon update 06/2026
error
[2221-1] ...... xentry\bin\GlobalEnvSettings_PROD.properties
Make a screenshot.
error
Restore original file, then run fix again and select only activate Xentry option.
RE: Support thread for FullFixbySamik paid version - Rabih AMG - 09-22-2026
Thank you! Now it works ok. But ignition does not read automatically only manually is that normal?
(09-22-2026, 09:22 PM)Rabih AMG Wrote: Thank you! Now it works ok. But ignition does not read automatically only manually is that normal?
It's depends from adapter and car.
