RE: Support thread for FullFixbySamik paid version - luki03 - 09-22-2026 (09-22-2026, 09:22 PM)Rabih AMG Wrote: Thank you! Now it works ok. But ignition does not read automatically only manually is that normal? w206 It's normal. RE: Support thread for FullFixbySamik paid version - DreamAutoInteriors - 09-23-2026 EDIT: this can be ignored - cleared C:\ProgramData\LicDir and reinstalled activation only and all is working well so far! Hello, I've uninstalled xentry openshell 2023, cleaned up generally and reg keys. Installed openshell 2026 26.9.4, bought activation key for latest fullfix, installed but I still get start key not valid when starting xentry. Looking in config assist it looks like it is still seeing old start key entry with old dates. When installing fullfix the login prompt appears, ive used my current account and also registered a new one just in case, but when loading xentry the login prompt isnt shown (im sure it needs to get past startkey error) Secure boot is disabled Defender and firewalls disabled Re-ran fullfix No errors during fullfix install Any help on this? Or maybe I need to just manually enter a startkey because I had one before? If there is a reg key or file that will remove the start key entry i can try that if you let me know. Thanks for the help! RE: Support thread for FullFixbySamik paid version - sepy123 - 09-23-2026 I have installed XDOS 09.2026 and Samiks paid full fix. I choose installation of DTS Monaco 8.16 and also 9.02. Currently I'm trying to get DTS Monaco 8.16 to work with my SDConnect but it doesn't. SDConnect Toolkit finds SDConnect via wifi, Xentry, DAS all working. Just DTS Monaco not. Anything I need to do to get it working? Thanks for help RE: Support thread for FullFixbySamik paid version - Sam!k - 09-23-2026 (09-23-2026, 12:46 AM)DreamAutoInteriors Wrote: Hello, Clean up generally and activation key in his place. Fix for clean system! Try delete LicFir folder from ProgramData, then activate again. (09-23-2026, 01:06 AM)sepy123 Wrote: I have installed XDOS 09.2026 and Samiks paid full fix. Run fix again and select only checkbox Fix DTS for work with SDConnect. RE: Support thread for FullFixbySamik paid version - sepy123 - 09-23-2026 Tried to run fix again but it still doesn't work. Attached pictures of Interface Configuration, is this correct? SDConnect shows up in toolkit and also working with Xentry / DAS. Tried it via lan connection, there it's working. What am I doing wrong with Wifi connection? RE: Support thread for FullFixbySamik paid version - sepy123 - 09-24-2026 Now I also have issues getting SDConnect working in Vediamo. Can you help here also? RE: Support thread for FullFixbySamik paid version - Sam!k - 09-24-2026 (09-23-2026, 11:07 PM)sepy123 Wrote: Tried to run fix again but it still doesn't work. (09-24-2026, 01:33 AM)sepy123 Wrote: Now I also have issues getting SDConnect working in Vediamo. Let imagine, you installed Xentry 09.2023, which working with SDConnect in stock. Let's imagine you downloaded and installed DTS and Vediamo here. How you should make them work with SDConnect? It's the same. Fix's work make SDConnect work with Xentry and DAS, simple install DTS, Vediamo and activate them. P.S. At the first, always check it with cable, if it's working with cable and didn't working via wi-fi, you will know how exactly make search, to find solution for a problem. RE: Support thread for FullFixbySamik paid version - sepy123 - 09-25-2026 (09-24-2026, 02:20 AM)Sam!k Wrote:(09-23-2026, 11:07 PM)sepy123 Wrote: Tried to run fix again but it still doesn't work. That answer not really clear and helping. I installed XDOS 09.2026 and your paid fix solution. During your fix installation I choosed install DTS and Vediamo. XDOS working fine via wifi connection. So I thought DTS should work also, but DTS only working with cable? Vediamo not working at all... Any useful tips? Vediamo I got working, the patch was missing. But how to get DTS through wifi working? RE: Support thread for FullFixbySamik paid version - Autodiag2022 - 10-07-2026 I installed OpenShell 06/2026 and purchased SamFix specifically to use the C4 diagnostic toolkit. Everything is activated and working correctly according to the activation status. I also successfully updated the C4 device through the Toolkit Administration. However, I have a problem when connecting the C4 diagnostic interface to a vehicle. Xentry successfully detects the vehicle and reads the VIN/chassis number, but after that it gets stuck on: “THE DATA ARE BEING LOADED – PLEASE WAIT…” It remains on this screen and does not continue to the vehicle identification/diagnostic session. I have already checked the configuration and followed the recommended procedure, including switching between VCI mode and SDConnect mode and allowing the connection through the Windows Firewall. The C4 device is detected correctly, and the VIN is read successfully, so communication with the vehicle appears to work initially. The problem occurs immediately after the VIN is read, when Xentry tries to load the vehicle data. I have attached screenshots showing the problem. Could you please advise me what needs to be changed or configured to resolve this issue? Thank you in advance for your assistance. |
