RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 11-07-2016
i will look the source of the batch file and upload it here. you can play with it.
i wish i could make good installment and nice menu in the next coming xmas holiday.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Venya - 11-09-2016
Hi Pesona,
thanks for your Work. With PKW more or less OK.
If I try to flash a Transporter eg. Sprinter 906 or Viano 639 occurs the error "ETN for model series XXX could not be found".
My XD Version is 09/2015 Windows XP German.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 11-10-2016
your sdflash folder (09-2015 in this case) doesn't have it. try to use sdflash from older xentry version (e.g 12-2014 sdflash), make iso image and mount it in virtual drive.
hope this help
RE: PKW/SMART Programming Offline 2015 & 2016. Tested work. - Muhmas - 11-12-2016
(07-29-2016, 12:51 AM)heiko_audi Wrote: ... But when I try to upgrade MEG on smart 450, then I get error message:
"Error: Service ´MainSmartFlashRelease´ not found"
What could be the problem? I´m working on 12-2015 native install win XP Compaq Evo N410c with C3 mux.
Same here with Dell630. Same version, i used your Offline Programming 2015 to 07-2016 ver 1.01.txt
Sweating
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 11-12-2016
His solutions work. I flashed at least 15 different control modules since installed.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Muhmas - 11-12-2016
Even MEG for smart?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - liakontas - 11-13-2016
hi pesona.
i also tested the offline programming and it worked on every car i used it..
the problem is that i dont know to make a batch file to use the online and offline programming...this is what i get when i use your menu offline or online..is it the problem on the file or on me?
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 11-13-2016
(11-12-2016, 10:59 PM)Muhmas Wrote: Even MEG for smart?
cmiiw, i read in many threads in this forum that MEG 450/451 can't be offline programming, but SAM, IC, TCU, EPS, Starter Generator are okay.
(11-13-2016, 12:34 AM)liakontas Wrote: hi pesona.
noted. I have upload the source on the first post. i tested on winxp and win7. for other OS, i simulate it as win7 but not tested.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Muhmas - 11-13-2016
Ok, i did not know that. Tup
