First Web Release: PKW Programming OFFLINE 2014 & 2015 - Printable Version
+---- Thread: First Web Release: PKW Programming OFFLINE 2014 & 2015 (/Thread-First-Web-Release-PKW-Programming-OFFLINE-2014-2015)
Pages: 1 2 3 4 5 6 7 8 9 10
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - Robert AMG - 12-16-2015
Thanks for your help,
i am not using online prog/scn
can i use the flash data that you loaded in my 64 bit 9-2015?
how can i extract the flash data from dvd 3? or i have to copy the folder from another complete installed version 64bit?
The size of my pkw sdflash folder is 6.53gb.
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - pesona - 12-16-2015
As your question about the data, imo, it is not a problem at all.
Rocinante is one of the most experience members of mhhauto regarding this pkw programming.
I hope he would give you some enlightment about deeper use of this or you can pm him...
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - Pluto - 12-16-2015
(12-16-2015, 06:17 PM)Robert AMG Wrote: Thanks for your help,
Regarding extracting the flash data, all you have to do is mount the .iso file(flash data dvd 3) and when DAS Xentry needs the files it knows what drive, or you direct it to the correct drive to look for and extract the files accordingly--simply make sure the 32 is with 32 and 64 is with 64
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - Rocinante - 12-18-2015
I don't know what I can add here.. I only do online flashing and coding and haven't even tried out the offline fixes.. Sad
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - Robert AMG - 12-18-2015
i think the problem is in the aktab file itself, cause if u delete the aktab file it gives error no aktab file, so it means das is looking at the right folder, if aktab is there then it gives that it couldn't found the right flash, i think the aktab is not directing das to the right flash software, maybe.
also the offline prog is not working with w204 das in my system.
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - Leemyungjea - 01-03-2016
hi i install xdos xentry win7 x64 and c:
i can't PKW Programming OFFLINE
so someone help me this program
install guide plz...Smile
RE: First Web Release: PKW Programming OFFLINE & SCN OFFLINE 2014 & 2015 - pesona - 01-03-2016
(01-03-2016, 03:24 PM)Leemyungjea Wrote: hi i install xdos xentry win7 x64 and c:
hi,
actually, you just need to download the XDOS 64bit VERSION and run it.
btw,
What ecu do you want to program offline?
this thread is just for educational only..
i will update the first post which include the w204 in DAS to do offline and password free by clicking any character minimum 1 character...
but I need to know that it is needed or not by users...
hi,
btw,
thx for me answer
W212, W204 in DAS.txt file down
but
204_database.exe 204_menues.exe CBF_DAS_204.exe
cbf2014.exe file fail
it's "F:\programme\DAs\trees\pkw" message
help me
with your XDOS 64 bit version, it should be in the
partition C...
I will update the first post which included offline programming for w204 and x204 for 2015
If you can install the 204 files yourself to C, then you have to download the latest inbetrieb.ini from first post
