SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - Printable Version
+---- Thread: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP (/Thread-SDconnect-Toolkit-INTEGRATION-TO-NEW-XDOS-VERSIONS-03-2024-UP)
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - Azzatec - 07-09-2025
I installed this in XDOS 03.2025 using an SDConnect clone. DAS works like it should but HHTWin gives me "Com port Assigned Close other use". HHTWin gets the right startup parameters tho. Anyone else got the same issue? Also firmware updates failed, probably because sdversion.dll and some other stuff is missing, I had to copy the firmware files to another notebook to flash it.
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - mhh0010 - 07-09-2025
With the sensible FIX, all modules run natively, as intended by the original installation, including AddOns- Upd, HHTwin, DAS etc.!
Post #48  Movie
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - gcs190 - 07-09-2025
(07-09-2025, 07:06 AM)Azzatec Wrote: I installed this in XDOS 03.2025 using an SDConnect clone. DAS works like it should but HHTWin gives me "Com port Assigned Close other use". HHTWin gets the right startup parameters tho. Anyone else got the same issue? Also firmware updates failed, probably because sdversion.dll and some other stuff is missing, I had to copy the firmware files to another notebook to flash it.
You may have added a toolkit to the system, which is simply not enough.
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - Fiorino - 07-10-2025
I've installed sdnc on fresh win 10 x64 but It has no connection with my device... Today will try with different c4 but maybe do you have any idea what could I check?
I suppose it should have connection even without xentry installation.
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - altan - 08-04-2025
It's not polite to simply not reply. I've been waiting for a response for weeks regarding password installation, and they haven't even bothered to reply. I've been a member of this forum for over 14 years, am polite to everyone, and help wherever I can. I'd like to know what criteria they use to respond. I'm deleting replies and thanks.
For your information, I've helped more people here in the forum than I think. I just don't expect any thanks or reputation for it.
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - mhh0010 - 08-04-2025
(08-04-2025, 04:37 PM)altan Wrote: Es ist nicht höfflich einfach nicht zu antworten seit wochen warte ich auf ein antwort wegen intallation password sie machen sich nicht mal die Mühe zu antworten. Bin inswischen mehr als 14 jahre mittlied in diese Forum , bin höfflich gegen jede , helfe auch wo ich kann . Möchte wissen nach welchen kriterien sie antworten . ich lösche Rep. und Danksagung.
That's a "great lesson" - "thanks", however:
1. We're in an English-speaking forum - you can't break the forum rules.
2. It's advisable to read the rules in my threads carefully to see who, in my opinion, is entitled to a password...
3. A forum member with register from August 2011 and (0) reputations + topics, and only (9) posts in the forum - is a lazy bum (parasite)...
PS: Anyone who is helpful in the forum and has proven themselves to be so will receive every support from me...
Accidentally writing in German is against the forum rules, but insulting is not. Those who live in glass houses shouldn't throw stones.
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - job - 08-26-2025
(08-26-2025, 11:51 AM)little-allien Wrote: Thanks and REP is done cann someone mail me passwort per PM i need it today because my car has big problems..
This is just to install the C4 driver. If Xentry wants to use C4, additional fix are required.
RE: SDconnect Toolkit INTEGRATION TO NEW XDOS VERSIONS 03/2024 & UP - mhh0010 - 08-29-2025
Now to explain again HERE
