RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pesona - 11-23-2016 (11-23-2016, 01:52 AM)maxpower879 Wrote: I get it. Now everythink work. Thanks hi mate, thanks for the feedback. i see you use xdos 09-2016. would you kindly add information, from which sdflash version you get the needed flash file? i am sure that information will help this forum members when need it. thanks in advance p.s: i already upload some versions of SDFlash in the 1st post of this thread. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Fabiuz - 11-24-2016 I have succesfull test snc offline in smart whit release 2016.7 Tnk's I have used: file csdsmart.dll in DAS\SMART Rename Flashen in FlashenORI Extract folder Flashen from archive SMART OFFLINE 2014-2016 and Launch MENU OFFLINE ORIGINAL MODE PKW_SMART_TRANSP 1.1.exe RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Muhmas - 11-24-2016 ![]() do you extract to: c:\Program Files\Mercedes-Benz\DAS\trees\smart\ or to: c:\Program Files\Mercedes-Benz\DAS\trees\pkw\ or both? RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 11-24-2016 Smart dll goes in the smart folder. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Muhmas - 11-28-2016 Ok, that´s clear, but the "Flashen" Folder also? Or did you copy them to: c:\Program Files\Mercedes-Benz\DAS\trees\smart\ or to: c:\Program Files\Mercedes-Benz\DAS\trees\pkw\ or both
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 11-28-2016 Neither. Rename original file and copy new file into the corresponding folder. Done. Tested to activate Softtouch and no TAN needed. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Muhmas - 11-29-2016 You talk about csdsmart.dll right? ![]() But i ment "Flashen" folder and not the F2-Cheat for special funktions.
RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - Mackhack - 11-29-2016 Rename the original folder and copy the new folder next to it. RE: DAS PKW/SMART/Transporter Offline Programming 2014+2015+2016.Tested and updated. - pcsmed - 12-08-2016 hi have an problem with DAS xentry 2016 and C5 trying to software update my command in my w221 420L cdi from 2007 EU car i have the offline programming working. [attachment=157975] here i press F3 [attachment=157979] now i am getting this message the vin number is correct i press F2 [attachment=157980] and i get this i press OK [attachment=157981] do i have the wrong Akttab file ? i used the one from the first post i press F3 [attachment=157982] i don't have that CD do i need it ? if so do any one have the cd number for my car or do any one have a solution thanks to pesona for this offline solution it almost works on a w221 ![]()
