DAS PKW/SMART/Transporter Offline Programming 2014+2015-2020 - pesona - 07-26-2016 What's new:
DAS PKW/SMART/TRANSP Offline Programming & Online/Offline Entry of Retrofits & Modifications purpose:to update ecu firmware & Offline/Online Entry of Retrofist & Modifications Note: Change to original mode when update addons. Daimler always update to increase security in Online Programming!!! If not, the offline patch will get error when using. History: Rev 2.5: - For XDOS/XPT 2019-09 UP Rev 2.0 - Enable DAS Online/Offline Entry for Retrofits & Modifications (PKW) - Covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type) (Transp) - Recognize sdflash in virtual drive (Transp) Rev 1.01 - Add missing W204.041 (PKW) - Full flashen folder. Make it easier to switch between Offline and Online Mode and to avoid unnecessary error(s) because of copy/replace. (ALL) - Make example of menu file that you can use to choose Offline or Original. (ALL) Rev 1.0 - Add 204 vehicles for Offline Programming (PKW) 1.PKW Offline Programming, SCN Offline Coding & Offline Entry for Retrofits & Modifications Software: Xentry XP, XDOS(32/64) Release: 2015 - 07/2019. How to: 1. Rename original "Flashen" folder in: das\trees\pkw to "FlashenORI" 2. Extract and copy the offline flashen So in the das\trees\pkw you have two folders: Flashen : for offline programming FlashenORI : original folder. in case you need to use for online programming Make a simple batch file to have a menu to choose “OFFLINE” AND “ORIGINAL” to switch between these folders. It is better including changing the name of Flashen folders in SMART & Transporter too. ver 2.0: What's new in ver 2.0: - Enable DAS online/offline Entry for Retrofits & Modifications [attachment=238968] ver 1.01 What's new in ver 1.01 - Full flashen folder - add 204.041 [attachment=138950] notes: - for some xdos release, there is no akttab.csv in the PKW sdflash folder here it is: [attachment=138436] 2. SMART Offline Programming Software: Xentry XP, XDOS(32/64) Release: 2015 - 07/2019. Requirement: Need Offline Programming PKW installed how to: 1. Rename SMART Flashen folder in: DAS\Trees\Smart\Flashen to FlashenORI 2. Extract and copy the offline flashen DAS\Trees\Smart So in the das\trees\Smart you have two folders: Flashen : for offline programming FlashenORI : original folder. in case you need to use for online programming Make a simple batch file to have a menu to choose “OFFLINE” AND “ORIGINAL” to switch between these folders. here it is version 1.0: [attachment=138883] 3. TRANSPORTER/VAN Offline Programming Software: Xentry XP, XDOS(32/64) Release: 2015 - 07/2019. Requirement: Need Offline Programming PKW installed how to: 1. Rename TRANSP Flashen folder in: DAS\Trees\Transp\Flashen to FlashenORI 2. Extract and copy the offline flashen to DAS\Trees\Transp so you have 2 folders. Flashen : for offline programming FlashenORI : original folder. in case you need to use for online programming Make a simple batch file to have a menu to choose “OFFLINE” AND “ORIGINAL” to switch between these folders. It is better including changing the name of Flashen folders in ALL (PKW, SMART, TRANSP). here it is version 1.0: (q.e.d. proven here) [attachment=144415] 4. MENU This is example of menu file that you can use to choose Offline or Original. Compatible with: WINXP and latest OS For: Xentry XP, XDOS 32bit, XDOS 64bit Version: 1.1 (Include PKW, SMART, TRANSPORTER/VAN) What's new in ver 1.1: - copy to desktop. it will know what OS, and 32/64 bit automatically [attachment=146248] if the menu above is failed on your OS, here is the source file that you can adjust or delete the determination of OS. [attachment=154106] 5. PKW & SMART Offline programming for XENTRY XP Software: Xentry XP Release: 2014 Feature: Full Flashen folder + how to How to: (1.01) 1. Rename original flashen folder in: das\trees\pkw to e.g: flashenORI 2. Extract and copy the offline flashen [attachment=138951] 6. Transporter Offline programming for XENTRY XP Software: Xentry XP Release: 2014 Feature: Full Flashen folder + how to How to: (1.0) 1. Rename original flashen folder in: das\trees\transp to e.g: flashenORI 2. Extract and copy the offline flashen [attachment=144414] TRANSPORTER/VAN AKTTAB.CSV here is replacement for missing "akttab.csv" in Transporter e.g 12-2015, 09-2016 version etc [attachment=144366] 7. Transporter INBETRIEB.INI V2 Released in 03-2017 for All DAS Version : what's new: 1. it covers ALL Transporter vehicles in DAS (from 4 transp type to 16 transp type) 2. it will recognize sdflash in virtual drive [attachment=171870] how-to: - extract & replace the inbetrieb.ini of the "offline Flashen" in: DAS\trees\Transp\Flashen\ini\ here it is: [attachment=171871] 8. CD SDFlash Mini 2.0 If your sdflash in harddrive is not good/complete/missing a file(s), DAS will try to look for SDFlash CD. Fix that sdflash or Mount this sample CD SDFlash Mini in virtual drive when doing offline programming. what's new ver 2.0: - add FDOK folder from SDFLASH 10-2008 up to 03-2018 (PKW, SMART,TRANSP) [attachment=239503] Disclaimer: for official and educational use only. If you use them for any illegal purposes (such as programming stolen car/smart/van), this is your own responsibility. i'm definitely against it. EDIT: Tips & Tricks Quote:I have tested Offline Programming with xdos 03-2018 myself in real diagnostic. I use self-made sdflash (combine 10-2008 up to 03-2018 sdflash) and standard sdflash 07-2014 (i choose because it still has many etn* inside) Quote:DAS only allows max 3 new firmware in one sdflash. for xentry version 2017-12, here is good information from xzt in post 188:. (12-02-2017, 08:46 PM)xzt Wrote: Hi, I was tested your file pesona on version 12.2017, and after few test not work , but I was find that are missing some file, I was search old dvd flash data,to work normaly you need folder FDOK,file etns,etnh,etnt,etc from version old 2012,2011,2010,2009,for pkw,transp,smart tested and work fine in simulation with real vin car ! Q: (02-09-2018, 08:04 PM)megacrazy Wrote: Thanks for putting work into this pesona. A: (02-10-2018, 09:10 PM)megacrazy Wrote: So i figured this out. For some reason as soon as I changed my DAS.inf version/date to match the flash data date it started working. The next issue was missing #FDOK folder which I copy/pasted. Everything worked after that. (02-11-2018, 12:22 AM)megacrazy Wrote: I copied the entire 2016.5 release folder to SDFlash\Release. The "profi_cd.ini" file in that folder had "DAS-CD-NR=05/2016" Another links: SDFLASH-Collections SDFlash Collection 2008-2017 (torrent) RE: PKW/SMART Programming Offline 12/2015 & 2016 - alexjx - 07-26-2016 thanks for the great share! and i found out i am damned. i have applied the "no password and offline programming" patch without backing up first. is there anyway i can undo everything? i am on xdos 05-2016 (x64) which files should i rename/edit? thanks! RE: PKW/SMART Programming Offline 12/2015 & 2016 - pesona - 07-27-2016 no problem mate. here is for you, original flashen folder xdos 05-2016. [attachment=138497] p.s: because of my limited attachment quota in this forum, i will keep the link only for a week. have a good and success day mate. RE: PKW/SMART Programming Offline 12/2015 & 2016 - alexjx - 07-27-2016 (07-27-2016, 05:00 AM)pesona Wrote: no problem mate. thank you! i have downloaded the files and will try it when i get to the shop. RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - pesona - 07-27-2016 Today i go to my friend to test this offline programming myself. W204 and W211. Tested and it works. [attachment=138567] [attachment=138562] Now, i need your help mates. 1. I was ask by a member here that he stumbled with release code and test digit 2, like this: [attachment=138553] where do you get this numbers? i think i know how to bypass it if i connect with the car and stumble with that. but i need to know, if you don't bypass these numbers, where and how do you get this number from? 2. am i safe if don't connect battery charger? offline programming commercial vehicles, wil begin after switch engine and start OFF. That's why i have peace in mind and don't need battery charger. for pkw, i read that the fan will on hardly etc etc.. i will continue with F3. but before that i need the information please. RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - alexjx - 07-27-2016 (07-27-2016, 04:16 PM)pesona Wrote: Today i go to my friend to test this offline programming myself. as for #2, i normally dont plug in an external battery if the voltage is above 11. i only plug it in when it drops below 10. so its ok not to plug in an external charger. RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - pesona - 07-27-2016 thanks mate, btw, have you ever find the need for release code in w211? RE: PKW/SMART Programming Offline 12/2015 & 2016. Tested work. - alexjx - 07-27-2016 (07-27-2016, 06:18 PM)pesona Wrote: thanks mate, sorry, i havent encounter this in my das(s) before. We might need some professional to help in this. RE: PKW/SMART Programming Offline 2015 & 2016. Tested work. - sisdisru - 07-28-2016 (07-26-2016, 05:10 PM)pesona Wrote: Hi, akttab.csv - which way to install this file? |
