Delphi / Autocom No vci found - Printable Version
+--- Thread: Delphi / Autocom No vci found (/Thread-Delphi-Autocom-No-vci-found)
Delphi / Autocom No vci found - TurboWarrior - 07-30-2016
Hi, all my delphi was working perfectly fine until I booted up a fresh copy of windows!
I need to update the frimware on the unit.. via usb cable but I can't do this because I keep getting NO VCI FOUND
however when I plug the delphi into the car and laptop via cable I get a solid light (BLUE)
It's connects though bluetooth with no issues!
I've installed FTDI VCOM but still no look when I go into device manger I get "USB Serial Port" and that only comes up when the delphi unit is plugged in
I'm running Delphi cars 2014 r2
RE: Delphi / Autocom No vci found - khomrericky - 07-30-2016
Send me Your Teamviewer ID and I will Help
RE: Delphi / Autocom No vci found - gabbiiiyyyy - 07-30-2016
(07-30-2016, 08:24 PM)TurboWarrior Wrote: Hi, all my delphi was working perfectly fine until I booted up a fresh copy of windows!
Right click on "USB serial port" and select Update Driver.
Selects looking into your computer and go to the software location.
Select OK.
You will be doing once the steps above and the new driver appeared (AUTOCOM).
Kolo
RE: Delphi / Autocom No vci found - TurboWarrior - 07-30-2016
Select OK.
Kolo
I attempted this earlier but it didn't work.. I've just done it again and it worked so I've sorted it now guys thanks!
