Sd Connect WiFi configuration problems on Win10 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Sd Connect WiFi configuration problems on Win10 (/Thread-Sd-Connect-WiFi-configuration-problems-on-Win10) |
Sd Connect WiFi configuration problems on Win10 - Istanbul - 08-23-2016 Hello Guys. I have successfully installed Xdos 07.2016 on Windows10. Everything is fine, but i can not connect it via Wifi. Previously on Win7 it worked without problems. I have described my steps on attached pictures. On Win7 this works, but on Win10 Road24h not appears.Sometimes it appears but still not have communication. By the way, Ip addresses are already configured in correct way. Is here anyone who maybe knows what i am doing wrong? ![]()
RE: Sd Connect WiFi configuration problems on Win10 - laco210 - 08-23-2016 Maybe you forget this step. "Click Start > point to All Programs > right-click Startup > click Open. (You may choose Open All Users instead if you prefer). Right-click an empty space and click New > Shortcut. Type in "netsh wlan connect NetworkName". Once again, NetworkName must be substituted with the SSID of your ad-hoc network. Click Next and enter a fancy name such as "Connect to NetworkName" or something like that. Click Finish and you're done. This shortcut will run when Windows starts up, giving you a very brief flash of the black command window, followed by your computer connecting to the ad-hoc network if it is available. Tip: You can also pin the shortcut in your taskbar or copy it to the desktop to easily connect to the network any time you want." Copied from thread Xdos SDConnect configuration ![]() Your Adhoc will be started together with windows. Road24h Adhoc working under Win10. RE: Sd Connect WiFi configuration problems on Win10 - Istanbul - 08-24-2016 No, i have tried also this step, but it should work without this step because it is only for auto connection. Any ideas? RE: Sd Connect WiFi configuration problems on Win10 - andrius1989 - 10-04-2016 any more ideas? as i am facing same problem on win 10 too :0 RE: Sd Connect WiFi configuration problems on Win10 - smart.japan - 10-04-2016 Hello I was connected with also Task Scheduler |
