W208 ESP problem - Printable Version
+---- Thread: W208 ESP problem (/Thread-W208-ESP-problem)
W208 ESP problem - reddevil - 10-13-2012
hello m8's
a 208.365 car came to my garage and i accidentally activated the road test and then checked the fault codes and this fault appeared
C1540-008 Driving test: Road Test not performed.
the problem that when i check the ESP it turns to HTT mode
what can i do to fix it ??
RE: W208 ESP problem - webmaster - 10-13-2012
(10-13-2012, 02:59 PM)reddevil Wrote: hello m8's
Simply carry out the road test.
The steps are written on the scanner how to carry it out.
Best regards.
RE: W208 ESP problem - reddevil - 10-13-2012
Best regards.
what is " The scanner "
DAS XENTRY Pc
Anyway here is the way:
[Image: roadtest.gif]
Best regards.
RE: W208 ESP problem - darren_harper - 06-28-2016
Hi friends has some1 please got the procedure for this? Cant see the image
RE: W208 ESP problem - alexjx - 06-28-2016
erm, correct me if i am wrong
get a space big enough.
drive straight then turn steering left to right .
turn steering more than 10 degrees. until the triangle light turns off.
speed : somewhere 10-15kmph will do.
RE: W208 ESP problem - QBAelectric - 06-28-2016
you can turn it off through developer mode unless it goes on DAS.
RE: W208 ESP problem - Rayman123 - 01-22-2017
(06-28-2016, 09:42 PM)alexjx Wrote: erm, correct me if i am wrong
Did not Drive
RE: W208 ESP problem - gio777 - 01-22-2017
In control module adaptation activated road test end follow das instructios
