(SOLVED) W164 SCR/ADBLUE/NOX Deactivation - Printable Version
+---- Thread: (SOLVED) W164 SCR/ADBLUE/NOX Deactivation (/Thread-SOLVED-W164-SCR-ADBLUE-NOX-Deactivation)
(SOLVED) W164 SCR/ADBLUE/NOX Deactivation - Yoshimitsu - 09-05-2016
good evening mates,
we got an WDC 164.124... from 2010 here.
Somebody had stolen the complete exhaust system from it..
Sooo we have an exhaust system from WDC 164.122 here and thought about to put this 164.122 system in there, without DPF..
Is there any chance to deactivate this ADBLUE/SCR/NOX?
I played around in CDI, turned SCR off- but nothing changed.
Would be nice if someone can give me an advise for this Listen.
RE: W164 SCR/ADBLUE/NOX Deactivation - mike_service - 09-06-2016
Hello
Read and save file from ecu,i can help with scr off file !
Regards
Mike
RE: W164 SCR/ADBLUE/NOX Deactivation - Yoshimitsu - 09-06-2016
For read and Write this EDC17 ECU i will need to open it, right?
Update:
readed the file with ktag, sendet to someone who deleted that adblue things and than wrote it back.
problem solved.
thanks!
RE: (SOLVED) W164 SCR/ADBLUE/NOX Deactivation - burmaka - 11-04-2016
Hello forum members. I have w164 2010 as well and i have some problems with scr sensor. Star give following faults 135300 ,147600, 147700, 153600, 153800. Is it possible measure something from sensor is it working. Senor part number is A0009052900 ns 0004. if you disable ad blue system will these faults go away.
Regards
RE: (SOLVED) W164 SCR/ADBLUE/NOX Deactivation - siroce - 11-05-2016
i have solution adblue off pw me
