Cruise Control Not Working After Activation - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Cruise Control Not Working After Activation (/Thread-Cruise-Control-Not-Working-After-Activation) |
Cruise Control Not Working After Activation - entrealz - 09-06-2016 Hi All, I'm a 52 year old newbie with an mb star 3 setup. I have been pulling out what little hair I have left trying to get Cruise Control working on my Smart Brabus Roadster. I have a computer and electrical background, so I thought it should be an easy task to do. I bought a stalk control and fitted it and plugged in the laptop. I followed the steps required to activate cruise control, pressing F2 to continue, a message popped up saying it was activated successfully but on a road test it doesn't work. Any help would be appreciated. Many Thanks Leon. RE: Cruise Control Not Working After Activation - technonut - 09-18-2016 (09-06-2016, 10:00 PM)entrealz Wrote: Hi All, Hi, not sure how much help I can be as I only ever did this once.. Assuming that hat you fitted the stalks first then programmed..? Assuming that you have the smart tan code dll installed (cdsmart.dll) F2 to continue message.. When I programmed mine, selected the option and it worked gave a message about programming clocks/display was done in about 20 seconds. It may be worth putting in your vin to identify your car rather than detect by control boxes. Sometimes this can program incorrectly.. Annoying as this feature is, this is to prevent incorrect coding to the car so putting in the vin is a better option. you can find the default one in a txt file and edit this so if you are mainly working on your own car then change this to your vin and it wil save you adding it every time. if you didn't have a brabus, it might have worked. Where possible always use the correct vin and re-program then test. RE: Cruise Control Not Working After Activation - nanant - 09-20-2016 Did you installed the stalk correctly ? There is an additional wire to plug into the new stalk. RE: Cruise Control Not Working After Activation - Indigo - 12-02-2016 I did this myself recently and had the same problem. What I did wrong was; on connector N11-8, I accidentally put the Black/Green wire to pin 1 instead of pin 11. Pin 1 is not used and right next to pin 11 (in 2nd row). With the connector upside down and flipped over I didn't flip the 2 rows in my head, so what I thought was pin 11 was actually pin 1. Black/Green wire is cruise control power supply. |
