W163 AAM virgin - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W163 AAM virgin (/Thread-W163-AAM-virgin) |
W163 AAM virgin - Deplore - 09-16-2016 Hi, Have a 1998 W163 here. Crank, no start. B1703-003: The programmed code of the transponder is o.k., the programmable code is invalid. I think AAM is bad... because I have 3 keys here, and all keys give that same code, and all keys fail the test. Would like to virgin this and see where I get. I tried a virgin AAM file that was here on mhhauto, but did not work. Help appreciated. RE: W163 AAM virgin - Deplore - 09-17-2016 anyone? RE: W163 AAM virgin - Fontaine974 - 09-17-2016 (09-17-2016, 02:45 AM)Deplore Wrote: anyone? AAM 163 is a recurrent problem. Your EZS recognizes the different positions of your key? 30 , 50, 15, 15R? RE: W163 AAM virgin - Deplore - 09-17-2016 (09-17-2016, 09:13 AM)Fontaine974 Wrote:(09-17-2016, 02:45 AM)Deplore Wrote: anyone? It does, but AAM can't tell me the key number that is inserted. It always says "?" instead of key #1, 2 and so on. I am going to buy a used ignition coil ring, but would also like to try syncing the keys....since the W163 AAM uses a rolling code. RE: W163 AAM virgin - Rocinante - 09-17-2016 The rolling code is only for unlocking and locking I thought.. not starting.. Transponder ring failures are very common.. RE: W163 AAM virgin - Deplore - 09-18-2016 (09-17-2016, 11:13 PM)Rocinante Wrote: The rolling code is only for unlocking and locking I thought.. not starting.. Well, as I understand, it does have two codes. One code is to make it recognize it as a certain key, ie. Key #1, 2, etc. The other code is the rolling code that is changed every time the car starts. The new rolling code is programmed into the key chip. Just like BMW. That's what that code B1703 means. I went to junkyard and pulled out a transponder ring coil, a good working one, and installed it. Now in AAM, the AAM, immobilizer and key tests pass, no problem. But AAM still does not recognize the key number, and it still says the same code. So I'm hoping someone has means to virgin, or at the very least sync the rolling codes on my key to the AAM. RE: W163 AAM virgin - art_arev - 09-19-2016 Code B1703 Check the PDF & go to WIS docs it mentions & do some tests...... RE: W163 AAM virgin - Deplore - 09-19-2016 (09-19-2016, 01:46 AM)art_arev Wrote: Code B1703 That's....unfortunate. Going to dealer for key is last resort. I'll look up the relevant WIS doc. I ordered a bunch of chips, gonna swap them and program with MB key programmer/FVDI and see whats what. RE: W163 AAM virgin - avtoveronika - 10-19-2016 Your AAM says (has used keys N 1,2,3,4,5,6,7,8), and maybe you have conflict with ECU. I thing you need a virgin .bin to write back to AAM, and create new key who is not used. Example: has used keys N 1,2,3, - and in this way you can create new key with numbers 4-5-6-7-8. And maybe will start. I attach your bin edited, now your used keys are N 1 and 2. You can try to write it back to AAM, and program one non used key like 3-4-5-6-7-8. |
