AK500+ VMWARE (WINXP) - Printable Version
+---- Forum: VMWARE Pre-installed Images. (https://mhhauto.com/Forum-VMWARE-Pre-installed-Images)
+---- Thread: AK500+ VMWARE (WINXP) (/Thread-AK500-VMWARE-WINXP)
Pages: 1 2 3 4
AK500+ VMWARE (WINXP) - narkeleptk - 09-20-2016
I've updated my AK500+ VMWARE for better function.
This is stand alone ak500+ in windows XP. VM is set in non-persistent mode so if you need to make changes you will need to turn that off. I like to leave it on myself.
I do not recommend installing anything else as it likes to cause trouble with IR key write program.
No Pass.
RE: AK500+, SKC, NecProg & IR PLUS - narkeleptk - 10-27-2016
Just an update:
I have a few laptops that still do not work with the NEC/IR write software.So far its 3/5 from my testings. Nec gold box is working great on every machine tho so I'm thinking its something to do with the usb drivers for AK500. Gold Box uses same program but different drivers.
Also, sometimes when running the nec/ir write software from ak you will get HARDWARE FAILED. Try to select the port a few times and it can go through.
RE: AK500+, SKC, NecProg & IR PLUS - daxxer - 10-27-2016
(10-27-2016, 03:42 AM)narkeleptk Wrote: Just an update:
yes, FTDI drivers are different and then problem...Listen
RE: AK500+, SKC, NecProg & IR PLUS - bgd77 - 11-01-2016
(09-20-2016, 07:16 AM)narkeleptk Wrote: Ak500+ is a pia to get working so here is a vm i fixed up.
also included:
-SKC 1v06
-MB NEC KEY PROG (gold box)
-MB IR PLUS PROG
OS is XP SP3 black edition. made in vmware10 for vmware10.
all tested and working on 3 different laptops.
thanks + reps then pm for pass.
pass please thanks
RE: AK500+, SKC, NecProg & IR PLUS VMWARE - mohcin2 - 11-30-2016
PLEASE PASS
RE: AK500+, SKC, NecProg & IR PLUS VMWARE - anis_9 - 12-05-2016
also included:
-SKC 1v06
-MB IR PLUS PROG
please the password
Thank you
RE: AK500+, SKC, NecProg & IR PLUS VMWARE - narkeleptk - 12-05-2016
also included:
-SKC 1v06
-MB IR PLUS PROG
please the password
Thank you
press +reputation, +thanks, and then send PM for password.
RE: AK500+, SKC, NecProg & IR PLUS VMWARE - komote - 12-24-2016
please the password
Thank you
RE: AK500+, SKC, NecProg & IR PLUS VMWARE - khalid farhan - 01-18-2017
also included:
-SKC 1v06
-MB IR PLUS PROG
