Comand W221 - Printable Version
+---- Thread: Comand W221 (/Thread-Comand-W221)
Comand W221 - Roberto - 10-03-2016
My hard drive stopped working (HDD Toshiba MK4036GAC). Data recovery not possible.
Can someone tell me if I it's possible to swap the old one for a normal store-bought hdd? Will there be any problems with missing files? I have a new navigation DVD if needed.
Someone has a HDD image for me?
RE: Comand W221 - e500 - 10-03-2016
(10-03-2016, 04:32 PM)Roberto Wrote: My hard drive stopped working (HDD Toshiba MK4036GAC). Data recovery not possible.
I will be honest as I am speculating, but my best guess would be I believe that you will need the correct hard disk image of a working unit for whatever model you have (pre- or post-facelift) and country. A store bought 2.5 inch HDD would probably work fine, although you probably will not be able to locate one as small as the one in the COMAND. I am not sure if it is SATA or PATA, but the HDD could be hardware locked where the device it is connected to (the COMAND in this case) passes an unlock password to the HDD as soon as it powers up, only then will the HDD read the data to the device. There have been workarounds for these protections if it indeed incorporates it, but it does make it difficult for someone without in-depth knowledge of hard disks to retrieve the data on a PC and make an image of it without tools to unlock it assuming its locked (I don't know for sure it is, but I would guess yes, similar to game consoles, etc.).
If it is locked, that could in fact be the reason you cannot retrieve data from it currently. I would assume it is formatted FAT32, and I would clone an image the same size (20GB or 40GB) and leave the rest (say 440GB) unpartitioned.
Maybe someone with first-hand experience can chime in on this. Good luck.
