EZS problem - Printable Version
+---- Thread: EZS problem (/Thread-EZS-problem--108661)
EZS problem - Digidiagnosis - 10-03-2016
Hi,
I want your help.
Mercedes c180
Car EZS propably damaged ....no files available from mcus (hc05)
I have second hand EZS , car esl, car key and New blank key.
What can I do to start the car?
I don't have the car at my office, what solutions do I have on bench?
I am thinking to make virgin the esl and make new key with generate key from the second hand EZS ....
I shall wait for your reply
RE: EZS problem - stachu121 - 10-04-2016
Ok, but if you want to make virgin esl you must virgin ecu too. If You will not make virgin ecu on new EZS the car won't crank.
RE: EZS problem - Digidiagnosis - 10-04-2016
(10-04-2016, 01:53 AM)stachu121 Wrote: Ok, but if you want to make virgin esl you must virgin ecu too. If You will not make virgin ecu on new EZS the car won't crank.
Thank you for your reply
So, if make virgin esl and virgin Ecu , generate new key for the second hand EZS, then shall I do something more ? Or the car is ready to go?
RE: EZS problem - efka - 10-04-2016
No its not .You must adapt ESL and engine ECU to EZS . Then it should start
(10-04-2016, 11:13 AM)efka Wrote: No its not .You must adapt ESL and engine ECU to EZS . Then it should start
I have way to make adaptation on car but I try to find solution without the car. Can you help me to finish this on working bench ?
RE: EZS problem - efka - 10-05-2016
just make yourself bench wiring and do it there.
RE: EZS problem - Digidiagnosis - 10-05-2016
(10-05-2016, 12:29 AM)efka Wrote: just make yourself bench wiring and do it there.
I understand.
Customer probably will send the modules at the next days....if not decide the mercedes dealer solution.....I will update here if receive the modules
Thank you
RE: EZS problem - Digidiagnosis - 11-29-2016
Please see attached file.
Can someone make it virgin?
RE: EZS problem - nawwizard - 11-29-2016
(11-29-2016, 03:11 PM)Digidiagnosis Wrote: Please see attached file.
