sensotronic brake faulty - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: sensotronic brake faulty (/Thread-sensotronic-brake-faulty) |
sensotronic brake faulty - william87 - 10-06-2016 i had problem with the sensotronic brake system gives a fault pressure reservoir faulty the esp system ok the warning braking reduced always on the car as i think around 2007 any help please RE: sensotronic brake faulty - craig coopen - 10-06-2016 Change hydraulic unit RE: sensotronic brake faulty - mersum1es - 10-06-2016 If its reservoir only, you can change only that (no need change whole unit) RE: sensotronic brake faulty - craig coopen - 10-06-2016 Most cases I had I changed whole unit cause by changing reservoir never helped |
