C180 W203 Visit workshop SRS - Printable Version
+---- Thread: C180 W203 Visit workshop SRS (/Thread-C180-W203-Visit-workshop-SRS)
C180 W203 Visit workshop SRS - shifty1976 - 10-07-2016
Good evening,
Wondering if any of you guys can offer a little assistance with this issue,
9077 - VINs in control modules restraint systems control module and EIS control
module are not identical
Seems quite simple i know, But i dont own star / Xentry !!
Is there any way i can make the Vin's match by opening up the offending units and using Xprog / Upa ??
Thanks for reading, Any help would be greatly appreciated ..
RE: C180 W203 Visit workshop SRS - malguy - 10-07-2016
You replace SRS module with used unit or fault appear itself with old module ?
RE: C180 W203 Visit workshop SRS - shifty1976 - 10-07-2016
For now i'm going to assume the SRS module is the original one for the car,
Reason for that assumption is the unit pretty difficult to get to and it looks like nobody has removed the center console in years !! Even found some lose coins trapped in places Cheer2
The unit has CR16MCT9VJE7 Which i dont think i have the equipment to read it, Reading the forums im lead to believe i'l need to add something like carprog to my collection of tools !!
So for the next step i believe i can investigate the VIN stored in the EIS using my Xprog !! So thats my intention despite it looking so scary, Read lots of posts on this and got a couple different connection pictures from here, I dont actually know whats inside the EIS at this moment as i havent opened it up yet !!
Wouldnt mind some pointers from members that use Xprog for this purpose, Any special setting or order in which you have to read it ??
RE: C180 W203 Visit workshop SRS - mb_port - 10-07-2016
with star 5 minut job,disable vin check on airbag
I appreciate Its probably a 5 minute job with Star, But this doesn't justify the cost of a star system in my opinion, Its the first one of these i have seen !! If i was working on this kind of car daily then yes i agree .. And on the other hand i see this airbag control module is used in alot of other cars which im more likely to see in the future ! Maybe at some point i will have to bite the bullet and say i cant do this job i dont have the equipment, But first i must at least try, Worst case scenario i learn something from it !!!
Do you know of any reason i couldn't just write the correct vin to both EIS and SRS unit?? LoL apart from the fact i dont yet have a carprog to get the correct vin into the SRS controller ..
While im here could someone confirm this is the working connections for Xprog .. The EIS i have looks exactly the same on the inside !!
RE: C180 W203 Visit workshop SRS - gio777 - 10-07-2016
release control module and startup
RE: C180 W203 Visit workshop SRS - shifty1976 - 10-12-2016
So after hours and hours of reading about this, I found a PDF guide with instructions on how to make a "special cable" for Xprog, Made the cable followed the instructions and read the EIS unit, Il attach the dump so you experts here can look and see if its all in order .. I can see the correct VIN inside the dump when i look with hex editor!! So now i will assume the SRS unit has to be the culprit for this problem !
I have Xprog and upa-usb is their any way at all i can read CR16MCT9VJE7 device with either of them or will i have to invest in a carprog setup ??
Also if anybody here needs help with pinout for "Special cable" just ask, I searched and searched for it, Eventually found it !!
RE: C180 W203 Visit workshop SRS - efka - 10-13-2016
you are trying to get into the house through the roof. Firstly - reading your post - you do not have to remove center console to remove SRS unit. Secondly - turning off VIN check as mentioned by MB_PORT takes minutes and does not require any disassembly. These units do go bad. Or another case scenario - someone replaced EIS in this car - they do go bad as well. this would trigger same code. Do it right way - get an access to Xentry and just code it right.
RE: C180 W203 Visit workshop SRS - shifty1976 - 11-06-2016
In that case call me Santa ..
So the original question was IS IT POSSIBLE to complete this task without MB Star ..
The answer is YES ..
So i got a carprog, Took a while to actually get it working, But plenty of info here on carprog.
Then of course the cables are al wired up wrong, But after some perseverance i finally got their!!
2 digits of the vin appeared to be missing i re wrote them didnt work so then i did clear crash wrote that plugged it in YaY no more faulty SRS goto workshop..
If anybody else ever need help to achieve this with basic tools namely Xprog & Carprog post here or send PM i took pictures and made notes of the procedure ..
