Location of CFF,CBF and CCF files on Xentry Connect - Printable Version
+---- Thread: Location of CFF,CBF and CCF files on Xentry Connect (/Thread-Location-of-CFF-CBF-and-CCF-files-on-Xentry-Connect)
Location of CFF,CBF and CCF files on Xentry Connect - babijoe - 10-07-2016
Good morning All,
Please just asking, is it possible to copy these files CFF,CBF and CCF from the Xentry connect? Tried to used the file explore on connect but i could not have access.
Can anyone offer an advise on how, the tool is on lease and don't want break any warranty seals. Thanks
RE: Location of CFF,CBF and CCF files on Xentry Connect - Aless91 - 10-07-2016
You need to remove ssd and plug it as slave into normal computer.
RE: Location of CFF,CBF and CCF files on Xentry Connect - Fouad - 10-10-2016
if you have access it would be easy to copy and past otherwise you can go ahead with Mr. Aless91 suggestion.
RE: Location of CFF,CBF and CCF files on Xentry Connect - babijoe - 10-10-2016
(10-07-2016, 01:09 PM)Aless91 Wrote: You need to remove ssd and plug it as slave into normal computer.
Thanks, i was avoiding that option due to the warranty aspect.
(10-10-2016, 11:32 AM)Fouad Wrote: if you have access it would be easy to copy and past otherwise you can go ahead with Mr. Aless91 suggestion.
I will look for an alternative using the Network drive connection option available in Xentry Explorer. Thanks, appreciate.
send me team viewer via pm and I will give you access
I have already sent you a pm. Thanks
RE: Location of CFF,CBF and CCF files on Xentry Connect - carlo - 10-10-2016
(10-07-2016, 12:20 PM)babijoe Wrote: Good morning All,
Just use "servicing" log in and you can do all what you want. NerdFing32
RE: Location of CFF,CBF and CCF files on Xentry Connect - A2ua - 10-10-2016
What is that Servicing user? How to enter Connect with that user??
Thanks.
RE: Location of CFF,CBF and CCF files on Xentry Connect - Aless91 - 10-10-2016
Thanks.
RDP to Xentry Connect IP
