Permanent DTC P0562 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Permanent DTC P0562 (/Thread-Permanent-DTC-P0562) |
Permanent DTC P0562 - kino0924 - 10-10-2016 [attachment=148764] Hello. I have 2006 B200(W245) with permanent DTC code the code is P0562 which indicates "System Voltage Low" Recently, I changed Starter Motor(valeo oem) and Battery(kirkland) Before car starts, I can measure 12.3V from diag menu on dashboard. When car cranks, it drops to 10~11V but car starts without any issue. When engine is running, I get around 13.5~14.3V (depends on car's velocity) I initially thought I had bad battery so I tried with other brand battery but same result. Is it because I am using non-oem battery? Since the code is in permanent area, the code keep comes back to stored area which resulting check engine light on dashboard. After clear DTC from tool, next start is fine without any engine light. However, as soon as I turn off car and turn on, the code comes back. Since I dont have C3 Mux, I cant really test with star diag. Can someone please help me with this strange code? I really want to get rid of it from my dashboard but it keeps coming back which is really annoying. Thanks. RE: Permanent DTC P0562 - malguy - 10-10-2016 Post your VIN here, maybe your car have Aux battery. You need Das & Wis to diagnose this car. RE: Permanent DTC P0562 - kino0924 - 10-11-2016 I dont think I do have aux battery but here is the vin number WDDFH33X86J066446 Thanks alot! RE: Permanent DTC P0562 - Amaa - 10-11-2016 Did you jump start the car before? Does the battery need coding? RE: Permanent DTC P0562 - Artifact - 10-11-2016 First of all you need to check battery voltage on diagnostics or cluster. Better way is cluster for me. Turn ignition on I position, and press 3 times trip button, this is for W245 something like service mode. You can see there voltage, configuration and many other stuff, check if there is everything ok. After that, if it's ok, put diagnostic in car and check "voltage supply" and "sensor voltage supply" (this need to be 5V). If everything of that is fine than you need to repare ECU RE: Permanent DTC P0562 - diddydenton - 10-11-2016 Are you Sure there isn't a auxiliary battery in boot of vehicle. RE: Permanent DTC P0562 - kino0924 - 10-11-2016 (10-11-2016, 03:21 AM)Amaa Wrote: Did you jump start the car before? I did before but thats really long ago Im not sure I need to code battery but never heard any vehicle need battery coding If it does, thats really stupid.... (10-11-2016, 04:27 AM)Artifact Wrote: First of all you need to check battery voltage on diagnostics or cluster. Original method is result from diagnostic of reading cluster(I said i read it from dashboard) For checking "sensor voltage supply" you said put diagnostic. do you mean that do it with xentry? I dont have sdconnect at this time so I cant diag with xentry... (10-11-2016, 06:33 AM)diddydenton Wrote: Are you Sure there isn't a auxiliary battery in boot of vehicle. I checked WIS and everywhere and my car does not have auxiliary battery unlike other Benz RE: Permanent DTC P0562 - Amaa - 10-11-2016 (10-11-2016, 01:55 PM)kino0924 Wrote:(10-11-2016, 03:21 AM)Amaa Wrote: Did you jump start the car before? Some BMW and Audi need battery coding. I'm not sure about Mercedes. So it was just a suggestion
RE: Permanent DTC P0562 - kino0924 - 10-12-2016 (10-11-2016, 03:51 PM)Amaa Wrote: Some BMW and Audi need battery coding. I googled alot but I cant find any known story that Mercedes Benz required coding for new battery. |
