Mercedes C180 Central Locking issues - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Mercedes C180 Central Locking issues (/Thread-Mercedes-C180-Central-Locking-issues) |
Mercedes C180 Central Locking issues - Garrett - Adams Ltd - 10-10-2016 Hi Guys. I recently (2 months ago) bought a clean Mercedes C180 W202 1995 model. All was working well until a few days back when all of a sudden the central locking stopped working properly. The car would unlock but not lock. I brought in a so called Central locking expert who said the central locking pump was faulty and would need replacement. As a new one is not available to buy in my country (Kenya), I made an arrangement with a supplier of used parts that I would only pay after fitting the pump and seeing that it worked. Fitted 3 pumps (one out of a properly working car) and the problem remained the same. So obviously, the pump is not the problem. A number of "experts" have looked at it since but non has been able to locate the root of the problem and resolve it. Its like we have hit a brick wall. ![]() I now turn to you guys here, Please help!!!! RE: Mercedes C180 Central Locking issues - Decodec - 10-10-2016 You close car by key or by remote infrared key? Did you tried to open/close car from button on dashboard? Do you hear that pump is working when trying to open and close? RE: Mercedes C180 Central Locking issues - Garrett - Adams Ltd - 10-10-2016 Hi Decodec. As of now, I open with the infrared remote but I lock manually. Which button on dashboard? I am new to this car and the first time I have owned a MB so not very familiar. Yes you do hear the pump working both times for like about 3 to 4 seconds. RE: Mercedes C180 Central Locking issues - Decodec - 10-11-2016 So you must have an air leakage somewhere if the pump is working 3-4 seconds. Normally it's working 1-1,5 second. To check which line has air leakage, you have to do simple test in few steps. Disassembly from central locking pump one of many yellow line, and blind this slot by rubber cap or just by your fingertip to make it airtight. Now try to open and close your car. If problem still occur you insert back this line to the pump, and do the same procedure with next yellow line. RE: Mercedes C180 Central Locking issues - Garrett - Adams Ltd - 10-11-2016 But the pump in my car only has one vacuum pipe coming out from it. I am trying to attached a picture here but I don't know how to do that. I will as soon as I can learn how to do it. But the pump in my car only has one vacuum pipe coming out from it. I am trying to attached a picture here but I don't know how to do that. RE: Mercedes C180 Central Locking issues - Decodec - 10-11-2016 Here you are scheme of your central locking system: http://www.autolib.diakom.ru/CAR/Mercedes-Benz/1994/C220/SYSTEM%20WIRING%20DIAGRAMS/4861.pdf Firstly try to close car with button on dashboard as I said in 1st post. [attachment=148970] If it will not work you must do procedure that I described in my previous post. Air distributor is mounted probably on your central locking pump [attachment=148971] If the distributor is elsewhere you must find it and do procedure But I bet, that somewhere you have air leakage or all pumps that you've had were dead RE: Mercedes C180 Central Locking issues - Garrett - Adams Ltd - 10-11-2016 Tried to use the button on the dash. I hear the pump running both ways but it only unlocks. Does not lock. I will try looking for the distributor and blocking the lines next. Will revert. Thanks. RE: Mercedes C180 Central Locking issues - Garrett - Adams Ltd - 10-15-2016 Hi Decodec. Sorry for the late post. Seems there were some problems with the MHH site. Thank you so much for all your assistance and help. The system now works. I really don't know what was wrong. A guy came up with another used pump at a reasonable price and I just decided to try it, just for the heck of it, and presto! it worked!! Thank you so much once again. Now that this works, I can concentrate of solving other issues with this car. There is a problem with the idling for which I will start a new thread. Hope you will be able to help me with this as well. RE: Mercedes C180 Central Locking issues - Decodec - 10-15-2016 No problem, you are welcome. I had W202 for about 7 years, so I know something about that car and it issues :-) |
