Xentry start-problem - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Xentry start-problem (/Thread-Xentry-start-problem--109539) |
Xentry start-problem - VatoLocoVL - 10-12-2016 Hi, when i try to open xentry i see the logo for about 5 seconds then the logo close and xentry wont start. I reisntalled the whole system two times but everytime i get this error. DAS/WIS/EPC works correctly System Openshell 12.2015 Windows 10 32 Bit Can anybody help? Thanks RE: Xentry start-problem - lyserman - 10-12-2016 The search function will be your friend. If you had looked in the sticky section right above your post you will have seen this: http://mhhauto.com/Thread-Xentry-Not-starting-fix-xp-and-xdos-versions-no-password You can set your date back in BIOS manually too. RE: Xentry start-problem - Fouad - 10-12-2016 but don't forget to backup your files before applying the fix RE: Xentry start-problem - szumilaci - 10-12-2016 hello time back 2016 01 |
