W212 OM 651 fuel high pressure issue SOLVED - Printable Version
+---- Thread: W212 OM 651 fuel high pressure issue SOLVED (/Thread-W212-OM-651-fuel-high-pressure-issue-SOLVED)
W212 OM 651 fuel high pressure issue SOLVED - Raints - 10-12-2016
Hello.
I have a problem whit this car.
In idle speed high pressure is starting fluctuate, when engine temperature is aprox. 50-60 degrees.
No fault codes.
When engine cold all okay and when fully warmed also okay.
Just in the mid range temp,fuel pressure starts fluctuate and idle speed also.
Specified value should be +- 20 bar not more but when symptoms starts its more.
I made a back flow test in injectors, they all even, replaced fuel pressure regulator
back side on the rail.
Its not helped me.
Can somebody point me what do to.
Any help is appreciate.
BR
RE: W212 OM 651 fuel high pressure issue - A2ua - 10-12-2016
you replaced Y74 or Y94 ?
RE: W212 OM 651 fuel high pressure issue - Raints - 10-12-2016
I replaced Y74 pressure regulator valve.
Which is on the rail back not in front.
Y94 is quantity control valve which is on the high pressure pump.
Ah I see you mentioned even in the first message, my bad.
How does it looks like? Does idle speed jumps up or down for like 0.2-0.5 sec and then stabilize again? How often it happens (once in a 1 min/5 min)? Does engine shut off sometimes when it happens?
RE: W212 OM 651 fuel high pressure issue - yriy - 10-12-2016
Y94 need replace
Hi,
car runs fine.
I test it whit xentry and when the syptoms starts, i see that fuel pressure is starting to fluctuate more then it should be.
And its feel bad when i engage D or R and holding brakes.
Rpm plays up and down 50-100 rpm.
It happened when temp is aprox 50-60 degrees.
It appears and then it disapears. Yes its like 0,2 0,5 sec
(10-12-2016, 09:51 PM)yriy Wrote: Y94 need replace
How difficult is to replace it?
Looks like i should remove all intake/EGR.
In CDI should be y94 test. If pressure will fluctuate during y94 test then I think you will get change y94 test result.
If its impossible to perform test during malfunction then I recommend to replace y94.
RE: W212 OM 651 fuel high pressure issue - Bogdan Beb - 10-13-2016
Engine starts with Y74, but after a short time switches to Y94. Check also, at idle, fuel quantity( 3-9 mg/).To be sure if the Y94 valve is defective, detached the electrical connector and see if the problem persists. If not, maybe the injectors have a problem( nozzle).
RE: W212 OM 651 fuel high pressure issue SOLVED - Raints - 11-30-2016
I replace Y94. valve and customer happy!Big Grin
