Pano roof motor change on w221 S550 - Printable Version
+---- Thread: Pano roof motor change on w221 S550 (/Thread-Pano-roof-motor-change-on-w221-S550)
Pano roof motor change on w221 S550 - e500 - 10-14-2016
Have a friend that has a pano roof problem on an S550. The motor appears to have seized. Is this a pretty difficult job? Does the entire headliner need to be dropped?
Thanks!
Also, resyncro in DAS is not effective, and moves the roller blind with glass open?
RE: Pano roof motor change on w221 S550 - megapali - 10-14-2016
not be removed all ceiling
if you just change the driving motor panoramic sunroof! , Changes in 30 minutes
Column A panels dismantled,
support glasses
Control board ceiling
sunshades
door seals and front pillar trim column B ,partially
Unclip the ceiling in the front section
change song and \
fit everything back
RE: Pano roof motor change on w221 S550 - e500 - 10-14-2016
The hall sensor is also reading wrong in DAS for the roller blind so it tries to close above its limits. Not sure it there are additional isssues or not. Roller blind moves fine, but attempts to move it beyond its limits. Unsure if glass motor is only issue or not.
RE: Pano roof motor change on w221 S550 - megapali - 10-15-2016
you tried to teach him again?
not remember if she menu for curtain-visor adapatare
RE: Pano roof motor change on w221 S550 - e500 - 10-15-2016
Yes. Teach in moves the roller blind in front forward beyond its limits, and shows a value in Actual Values much higher than normal (100x normal) but this value does change when it is moved. Actuating the glass clicks the motor but glass does not move. Disconnecting the motor, the relay can be heard clicking and when the motor is connected you can hear it attempting to move glass but it does not move, but the OCP panel lights dim like it is attempting.
What are the main symptoms of glass motor failure?
RE: Pano roof motor change on w221 S550 - benztech823 - 10-15-2016
(10-15-2016, 12:52 AM)e500 Wrote: Yes. Teach in moves the roller blind in front forward beyond its limits, and shows a value in Actual Values much higher than normal (100x normal) but this value does change when it is moved. Actuating the glass clicks the motor but glass does not move. Disconnecting the motor, the relay can be heard clicking and when the motor is connected you can hear it attempting to move glass but it does not move, but the OCP panel lights dim like it is attempting.
there should be a plastic circular clip on the headliner thats covered up by the drivers sunvisor. Pop that clip off and there should be the hex for the sunroof motor to manually turn it with a wrench. The electrical part of the motor have failed but the mechanical part may still be functional.
The hex part of the motor is unfortunately seized to the point the bolt is stripped. I find it odd that the both the roller blind and the glass are not functioning correctly. Not sure if the hall effect sensors have failed or what it could be. Still diagnosing it.
hall sensor is incorporated in the electric motor
see you can have surprises to change the electric motor and hatch have mechanical problems on the trigger levers and hinges.
get off the electric motor cover Loosen the worm wheel,
between lid and wheel spacer washer put, I guess you drive teeth salt,
you can turn worm wheel and mount and vice versa, but you do not forget to put the washer. so you can pick the place if worn Pinon Drive for Cable
after doing some shares closed maximum fit and maximum open and hold down the button until you hear decoupling relay, then just learn the new position. These are all valid if the mechanical elements work well and have not broken
sorry but I I wanted to write to you quickly and I used translator, I hope to be understood what I tell them
RE: Pano roof motor change on w221 S550 - e500 - 10-16-2016
Hope to help friend remove it tomorrow and will know more. Will post what I find.
