Xentry SDconnect error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Xentry SDconnect error (/Thread-Xentry-SDconnect-error) |
Xentry SDconnect error - JanS211 - 10-17-2016 Hello, I bought a SDconnect C4 MUX with Xentry 09.2016. I put the HDD that came with the MUX in my notebook and set the connection tho the C4. Everything works fine. But if I start a short test the DAS could scan a few control units after it breaks down. A beep sound appears and the Battery voltage drops to 0 volt for 5 seconds but the car is always connected to a battery charger with 14 volt. Then this error message comes. (sorry it's in German i could set DAS in English and take a new picture). The c4 is always on and while the error appears it shows "Device not in use" in the display. There is no difference between LAN or WLAN always the same mistake.Any ideas ? Thank you! Greetings from Germany ! RE: Xentry SDconnect error - Fouad - 10-17-2016 i send you a pm check please |
