sprinter 906 injector driver blown - Printable Version
+---- Thread: sprinter 906 injector driver blown (/Thread-sprinter-906-injector-driver-blown)
sprinter 906 injector driver blown - silverdollar - 10-17-2016
Hi
we have a 906 2007 sprinter with blown injector driver. Customer has a scrapped 2nd van to take parts from same year same ecu partnumbers. What items need to be swapped apart from engine ecu, EZS and steering lock for the van to start and function properly. Have mb c4 to work with
thanks regards
RE: sprinter 906 injector driver blown - efka - 10-18-2016
to start these 3 things are enough but you will run into coding differences in EZS. And will have issues with instrument cluster and airbag because of different VIN and ID. I would rather renew used donor ecu and marry it to the vehicle. Do not forget to transfer injector codes .(write values from old ecu and enter to the donor)
If I helped - REP and (or) thanks are wellcome
