Retrofit hvac from w212 to w204 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Retrofit hvac from w212 to w204 (/Thread-Retrofit-hvac-from-w212-to-w204) |
Retrofit hvac from w212 to w204 - Benzdriver23 - 10-18-2016 Hi, I retrofitted an hvac air conditioning control panel from w212 in w204. Now is Start stop system not available. Ecu is from 2009 and the car is 2014. I need a cff for flash to make start stop system work. Has anyone a cff file (number) to flash this? Many thanks [attachment=150004] RE: Retrofit hvac from w212 to w204 - gurgel - 10-18-2016 Use this: 2129022109 RE: Retrofit hvac from w212 to w204 - Benzdriver23 - 10-18-2016 Thanks gurgel. Is this 2 Zone ece version? RE: Retrofit hvac from w212 to w204 - hans453 - 10-19-2016 Hello gurgel, can explain how you found the numbre? RE: Retrofit hvac from w212 to w204 - MegaCar - 10-19-2016 (10-18-2016, 01:40 AM)gurgel Wrote: Use this: 2129022109 Dear Sir, Please can you tell me how you determine the exzct number of cff file that we must use. Thanks |
