WIFI router for SDConnect - Printable Version
+---- Thread: WIFI router for SDConnect (/Thread-WIFI-router-for-SDConnect)
WIFI router for SDConnect - Rocinante - 10-18-2016
My WIFI router is starting to die and need recommendations for routers that don't give you the Java error. I had and Asus top of the line router and it errored out Java in Xentry all the time. The D-Link I have now works great but is loosing connection on the WAN port.
Please share what works and what Doesn't
For me,
Works:
D-Link DIR-655
Asus RT-N12
asus onhub
tplink archer c7
Didn't work:
Asus RT-AC3200
D-Link DIR-813
RE: WIFI router for SDConnect - Anturage - 10-18-2016
Never heard router does not work with SDConnect.
For me AirPort Extreme 2011 work fine
RE: WIFI router for SDConnect - Rocinante - 10-18-2016
I can't explain it but the router change fixed my Xentry Java error crashes. I changed laptops and WiFi cards in the SDConnect (original and clone) so I can say for sure the router was the problem.
Thanks for your input. Please, others give your recommendations. Smile
RE: WIFI router for SDConnect - PRoToTyPe - 10-25-2016
(10-18-2016, 07:09 AM)Rocinante Wrote: I can't explain it but the router change fixed my Xentry Java error crashes. I changed laptops and WiFi cards in the SDConnect (original and clone) so I can say for sure the router was the problem.
Tested yesterday tplink archer c7 Nod
RE: WIFI router for SDConnect - mercedessd - 10-28-2016
i use an asus onhub, works well
RE: WIFI router for SDConnect - Rocinante - 10-29-2016
I just ordered a D-Link DIR-813 AC750.. Its pretty cheap so I hope it works ok.. I'll report back when I get it set up and running
RE: WIFI router for SDConnect - Rocinante - 11-03-2016
D-Link DIR-813 does not work.. SDConnect MUX will not stay locked when trying to read VIN from car.. I tried two different MUX's and laptops..
Going to try an Asus RT-N12 D1 next..
RE: WIFI router for SDConnect - webmaster - 11-03-2016
I tested SDconnect on around 20 Different routers and never got any issue as well never looked to routers name...
Can I have a Team viewer Check?
Best regards.
I already packed it up and shipped it back.. I'll let you have a look when I get the new router and set it up..
Its really strange because the problems I have aren't the same with different routers and some routers work fine with no problems..
