DTC code. Need help with DAS Xentry - Printable Version
+---- Thread: DTC code. Need help with DAS Xentry (/Thread-DTC-code-Need-help-with-DAS-Xentry)
DTC code. Need help with DAS Xentry - brandnew - 10-18-2016
Good day, dear community
I need some help with DAS emulator function. I have a MB Sprinter 906 with DTC 2306-Sensor supply#2 voltage. I want to know what sensors are supplied by this voltage.
Can someone scout through the DAS in emulator mode and check out what solutions (check list) it gives for DTC 2306.
VIN: WDB90661319162133
MB Sprinter 2.2 CDI 2007 MY
Thanks is advance.
RE: DTC code. Need help with DAS Xentry - OmniVersatile - 10-19-2016
(10-18-2016, 03:31 PM)brandnew Wrote: Good day, dear community
Thanks is advance.
2306-SENSOR REFERENCE VOLTAGE 2 CIRCUIT LOW
For a complete wiring diagram, refer to the Wiring Information.
Theory of Operation
The ECM contains 3 internal 5-Volt Sensor Supply sources. Each 5-Volt Supply source is split into parallel circuits to provide 5 volts to multiple sensors. Sensor Supply 2 provides 5 volts to the Crankshaft Position Sensor, the Fuel Pressure Sensor, and the Boost Pressure Sensor.
When Monitored:
With the ignition on.
Possible Causes
INTERMITTENT DTC
5-VOLT SUPPLY CIRCUIT SHORTED TO GROUND
CRANKSHAFT POSITION SENSOR
BOOST PRESSURE SENSOR
FUEL PRESSURE SENSOR
ENGINE CONTROL MODULE
Fing32
