HHT does not start with DAS - Printable Version
+---- Thread: HHT does not start with DAS (/Thread-HHT-does-not-start-with-DAS)
HHT does not start with DAS - kalldall - 10-21-2016
Hi Guys,
If I hhtwin directly in the folder HHT (PKW, NFZ ..) calls it works without problems.
However, HHT is not started automatically by DAS.
Which file do I have to edit so the HHT is also automatically started by DAS ?
Can someone help me there ?
regards from KallDall
RE: HHT does not start with DAS - DBmhh - 10-21-2016
Which DAS release do you have?
RE: HHT does not start with DAS - kalldall - 10-21-2016
I use Version Xentry OpenShell XDOS 2016/09 with OS Windows 10
RE: HHT does not start with DAS - altera - 10-22-2016
[attachment=150656]Try this....
replace file in trees/pkw/programm/hht_link
RE: HHT does not start with DAS - kalldall - 10-22-2016
Hello altera,
I tried it but it does not work.
I have HHT installed in c: \ Program Files \ Mercedes-Benz \ HHT
If I here the HHTPKW start I get a error message.
(This is certainly a problem with the length of the path)
I install HHT in c: \ Program Files \ HHT so I can start HHT without problems
now i install Xentry, DAS, HHT in c: \ Program Files \
Then Xentry / DAS works without problems
HHTPKW start directly in the folder goes without problems but not the automatic from DAS.
Has anyone any idea how I can solve the problem ?
RE: HHT does not start with DAS - Kim1980 - 10-22-2016
(10-22-2016, 05:39 AM)kalldall Wrote: Hello altera,
HHT can be available before 2015.12 version
yes i known, but it should still work under Version 9/2016 on OS win10
RE: HHT does not start with DAS - art_arev - 10-23-2016
Your Win10 is 32bit, correct?
Download DieTrih's HHTWin final & reinstall it.
RE: HHT does not start with DAS - HestonDiag - 10-23-2016
I spent much time trying to crack this issue, but in the end I had to admit it was too difficult for me to find the reason, so I used the patch by Mr. DieTRih which works perfectly Smile
