change ezs w210 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: change ezs w210 (/Thread-change-ezs-w210) |
change ezs w210 - compan - 10-21-2016 Hi everybody,have problem to change ezs,e220 cdi in w210, i got ezs with working key,made it virgin esl and virgin ecu with autocoding file, after this looks ok,but stuck on ecu initialization,here is picture, can somebody explain where can be problem,or steps how to code ecu, thanks RE: change ezs w210 - pepi - 10-21-2016 Is there same part nr. of EZS ?? if no it wont initialized. RE: change ezs w210 - compan - 10-21-2016 different original was 210 545 02 08, replacement w208 545 01 08 RE: change ezs w210 - sanek - 10-22-2016 it is necessary install only 210 545 02 08, or 210 545 03 08(car restyling) RE: change ezs w210 - compan - 10-22-2016 One more question how is with remote?before was nec key and was work remote,how to fix it? RE: change ezs w210 - bawarek - 10-22-2016 It is not going to work. The personalization will not go thru as the Xentry somehow figures out that the new EIS has a different SSID that the original from the car. Perhaps there is an SSID stored in cluster or somewhere else, just as a back-up. This is only for 2000+ models, '98 and '99 no such problem. In case like that I find a complete set ECU, EIS, reset the ESL and all works fine. Look at this thread, same thing happens here. The car is 2000: http://mhhauto.com/Thread-W208-0-261-206-568-Virgin-problem RE: change ezs w210 - compan - 11-05-2016 So i found ezs with same numbers now ecu is personalized ok, and have a strange problem, on bench ezs with esl working ok,but when i put in car i cannot turn key and esl not locking, checked voltage coming to ezs and to esl,what can be? |
