Is this EIS/EZS problem? W204 - Printable Version
+---- Thread: Is this EIS/EZS problem? W204 (/Thread-Is-this-EIS-EZS-problem-W204)
Is this EIS/EZS problem? W204 - sigaik - 10-23-2016
I think so but before I do this job I want to be sure.
If I try with another MB key from another car it is the same, I can turn it around but nothing happens.
MB C200CDI MY2010 W204
https://youtu.be/r2IuWkBlm4I
RE: Is this EIS/EZS problem? W204 - mb_port - 10-23-2016
w204 212 95%esl damage
you can turn with all key,but without 15
RE: Is this EIS/EZS problem? W204 - sigaik - 10-23-2016
Okay, so I need to change ESL and not EIS. Thanks for good input!
RE: Is this EIS/EZS problem? W204 - paco88 - 10-23-2016
I think the same.
I don't hear the ESL unlock/lock when you insert/remove key.
Change the ESL or put an emulator if you can program it.
RE: Is this EIS/EZS problem? W204 - klonone - 10-23-2016
HELLO, elv is faulty,change
RE: Is this EIS/EZS problem? W204 - shmuk - 10-23-2016
change only electro motor , https://www.youtube.com/watch?v=UYsBxxOXoA4
RE: Is this EIS/EZS problem? W204 - alexjx - 10-23-2016
if u take another key from another car, insert it.
do you get the "Key does not belong to car" message on dash?
if yes, then most likely your ESL is broken. which is very common.
RE: Is this EIS/EZS problem? W204 - bawarek - 10-23-2016
It is 95% as MB_PORT mentioned, but a proper diagnostic is always recommended. I got caught a few times assuming it is the ESL and actually it was the key. What i found is that when you put the key in the ignition and the dash displays message "Please take your key" the problem is the ESL. If the dash doesnt display anything it is probably the key. I have repaired more than W204 200 ESLs and I didnt have even one faulty EIS.
