Panasonic CF18 Lan does not see SD connect - Printable Version
+---- Thread: Panasonic CF18 Lan does not see SD connect (/Thread-Panasonic-CF18-Lan-does-not-see-SD-connect)
Panasonic CF18 Lan does not see SD connect - mbaja - 10-24-2016
I havent seen this issue up to now: Panasonic CF18 connected via cable does not show any connection with SD connect but when connected to my router everything works. Tried changing TCP/ip settings (but it should not affect it - like LAN port is dead) by changing ip to 172.29.127.1xx but nothing helped.
When connected to router, shows that connection is establishing. When i connect SD connect to other laptop - everything works perfectly.
Anyone any advice?
Thanks in advance
RE: Panasonic CF18 Lan does not see SD connect - Anturage - 10-24-2016
Use crosover LAN cord. It has different pinout.
RE: Panasonic CF18 Lan does not see SD connect - RICARDO ORTIZ - 10-24-2016
Buy a better one that ones a piece of s***...
RE: Panasonic CF18 Lan does not see SD connect - mbaja - 10-25-2016
(10-24-2016, 04:19 AM)Anturage Wrote: Use crosover LAN cord. It has different pinout.
Thank you....That was the problem. FixedSmile
RE: Panasonic CF18 Lan does not see SD connect - mbaja - 11-02-2016
One problem fixed, another one popped up. I cannot install drivers for touch screen. I have downloaded them but obviously i don't know how to "apply" them since I have no "unknown device" in device manager and there is not application to install (or am I missing something - have all drivers for XP, for cf18 mk4). Anyone with similar problems?
