error [(1.2)-2.503.13011] - Printable Version
+---- Thread: error [(1.2)-2.503.13011] (/Thread-error-1-2-2-503-13011)
error [(1.2)-2.503.13011] - 996motor - 10-24-2016
Hello
Xentry 9/2016 with C4 Mux.
I Have this Error [(1.2)-2.503.13011]
In SDNC Mux show as connected. But if i connect with car i became this error
any help is appreciated
RE: error [(1.2)-2.503.13011] - Hesham Eldogry - 10-25-2016
Make sure the IP in your pc matched with SDNC
you can use this config
lan : 172.29.127.128
: 255.255.255.0
RE: error [(1.2)-2.503.13011] - ICEman-x - 11-04-2016
Hello, I have the same problem. The MUX IP and all settings are OK , because it works OK with older Xentry 05.2016. So, the problem must be somewhere else. Ip setting are the same in both versions. I do hope that some other Members will find solution.533 Thanks
RE: error [(1.2)-2.503.13011] - anonimo - 11-04-2016
I think this error caused so often that maybe all of you are using cloned HDD? Sorry for question. Best wishes to you.
Hello, What do you mean by "cloned HDD" ? If you mean HDD image restored from another PC, it should not realy matter. Should it? Wink If Xentry works on one PC, it should work on the other one, too. After activation of new licence of course. Aslo, please note that Xentry Simulation works OK. It happens only when the system is connected to a real car. Any other suggestions.... 533
RE: error [(1.2)-2.503.13011] - AutoExe3219 - 11-04-2016
replace the gbf folder in C:\Program Files (x86)\Mercedes-Benz\DAS\bin\
http://mhhauto.com/Thread-Xentry-WIS-StarFinder-09-2016-Win7-x64-Acronis-Image-Torrent
RE: error [(1.2)-2.503.13011] - ICEman-x - 11-05-2016
(11-04-2016, 06:08 PM)AutoExe3219 Wrote: replace the gbf folder in C:\Program Files (x86)\Mercedes-Benz\DAS\bin\
Hi, this was also sugested by other Members. Thankyou for your suggestion. It did the trick, but I wonder why the original folder is Not working 39 sttrange...
