e200 2001 i change the cluster it cant ignition on and remote key not working - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: e200 2001 i change the cluster it cant ignition on and remote key not working (/Thread-e200-2001-i-change-the-cluster-it-cant-ignition-on-and-remote-key-not-working) Pages:
e200 2001 i change the cluster it cant ignition on and remote key not working - iyad.nasser - 10-27-2016 e200 2001 i change the cluster it cant ignition on and remote key not working IR key what can i do any help please i wana start the car pleaseeee
RE: e200 2001 i change the cluster it cant ignition on and remote key not working - iyad.nasser - 10-27-2016 ??????? RE: e200 2001 i change the cluster it cant ignition on and remote key not working - mb_port - 10-27-2016 w211,can start without cluster,have you eis justage? RE: e200 2001 i change the cluster it cant ignition on and remote key not working - iyad.nasser - 10-27-2016 i open the ignition with jumper and i read the fault codes and the fault is p1570 so what i can do please? what eis justage mean please i dont know much about mercedes RE: e200 2001 i change the cluster it cant ignition on and remote key not working - mb_port - 10-27-2016 P1570 Fault in DAS to engine control module RE: e200 2001 i change the cluster it cant ignition on and remote key not working - iyad.nasser - 10-27-2016 yes so what i can do there is a guy say he want to take the egnition switch and the key to program them and it will work fine ? is that what the car want? any help please shold i let him take the switch and the key ? RE: e200 2001 i change the cluster it cant ignition on and remote key not working - iyad.nasser - 10-27-2016 ????? any help? RE: e200 2001 i change the cluster it cant ignition on and remote key not working - ryan4200 - 10-28-2016 What scan tools do you have? you could probably write the key your self depending on tools... RE: e200 2001 i change the cluster it cant ignition on and remote key not working - dominion1234 - 10-28-2016 Check the power in the steering lock and eis,may be power is missing in any of the components i mentioned. Hit the thanks bottom if i help. |
