License plate light W204 - Printable Version
+---- Thread: License plate light W204 (/Thread-License-plate-light-W204)
License plate light W204 - spark - 10-28-2016
Hi M8
I have retrofit the License plate light to LED.
It is a plug and Play version. Right now I got a fault mesage in SAM_R
(B177115 Signal light in Trunklid right circiut / no funktion/......)
The lights are working.
What part is to code in vediamo?
Help is appreciate.
Spark
RE: License plate light W204 - trigital - 10-28-2016
(10-28-2016, 08:51 PM)spark Wrote: Hi M8
Help is appreciate.
Spark
Better to post a picture from your diagnostic, your translate can suggest the light from inside the trunk...
RE: License plate light W204 - McDj85 - 10-30-2016
You can check the rear SAM codings to find settings for the license plate that have been set to "bulb" and try to change them to "led" and see if this fixes the problem. W204 with the new side markers on the mirrors should at least have these.
RE: License plate light W204 - tamba - 10-30-2016
Or you buy better qality of led lights,maybe is easier....
RE: License plate light W204 - spark - 10-30-2016
Help is appreciate.
Spark
I have problems with the lights inside the trunk too. All LED's are with resistors. All other LED's inside the car are working propperly and they are all from the same distributor.
I have searched the Bulb thing in te SAM rear but cant find anything. The only thing what is found is a setting with 12,3 Volt.
Any further suggestions
RE: License plate light W204 - pakiguy - 12-11-2016
(10-30-2016, 03:59 PM)tamba Wrote: Or you buy better qality of led lights,maybe is easier....
Agreed
don't reinvent the wheel
RE: License plate light W204 - master9999 - 01-18-2017
Help is appreciate.
Spark
As my understanding, in Rear SAM has less control coding than front SAM, the license plate light can be turned off by using DAS developer or VEDIAMO, but you can't suppress the error message from Rear SAM.
Fellows, please correct me if I am wrong.
RE: License plate light W204 - Aless91 - 01-18-2017
Help is appreciate.
Spark
Of course you can surpress the error messages. It is in Fehlercodefreigabe.
Help is appreciate.
Spark
Thank you Aless91, learnt from you again! you are really knowledgeable person in MB world! (not only, but also)
