W211_AIRmatic deletion - Printable Version
+---- Thread: W211_AIRmatic deletion (/Thread-W211-AIRmatic-deletion)
W211_AIRmatic deletion - turja - 10-31-2016
Hallo,
How can I deactivate the control block of Airmatic from my system? Air suspension is replaced with a normal steel suspension, but the AIRmatic is till giving me the error on the other control blocks. I can not find the Airmatic control block in central intreface. I have only done it in (KI) block.
Does anybody know how and where do I remove the Airmatic control block the right way?
RE: W211_AIRmatic deletion - Raito00 - 11-01-2016
You replace all suspension, front and back to metal springs ?
RE: W211_AIRmatic deletion - stachu121 - 11-01-2016
In EZS.
RE: W211_AIRmatic deletion - Hesham Eldogry - 11-01-2016
(11-01-2016, 03:56 AM)stachu121 Wrote: In EZS.
wrong answer NoNoits W211 all codes in the Central getway
you have to
Changing the type of assistants in CGW DriveDrive
RE: W211_AIRmatic deletion - turja - 11-01-2016
(11-01-2016, 12:25 AM)Raito00 Wrote: You replace all suspension, front and back to metal springs ?
Yes, replaced all suspension.
So!
You need reprogram with Star developer mode in this places:
Central Gateway
EIS
Cluster
and remove air-pump relay
(11-01-2016, 04:08 PM)Raito00 Wrote: So!
Central Gateway
EIS
Cluster
Thank you for your reply. The problem is that I searched all the codings and control blocks in the Central gateway and I could not find the control block for AIRmatic. Maybe it requires another sort of operation or menu? I was searching for it in the Cetral getway, where all of the control blocks are listed, but AIRmatic control block was just not there.
Central Gateway
EIS
Cluster
I think should be ..:
Central Gateway - Development - Control unit adaptions - variant coding
search there (in German) something: Luftfederung
RE: W211_AIRmatic deletion - Mackhack - 11-07-2016
It's more than what was posted to take it all out of the different control units. No need for developer menus.
Why in the world would one replace AIRmatic for some steel coil suspension? *head scratch*
