ML B1315 airbag fault - Printable Version
+---- Thread: ML B1315 airbag fault (/Thread-ML-B1315-airbag-fault)
ML B1315 airbag fault - laz79 - 11-03-2016
Calling all merc techs Big Grin !
Got Merc ML B1315 Airbag fault. Its passenger seat occupancy sensor. Customer doesnt want a fix, only light to come on and go off for annnual test. Questions:
1. Is it possible to turn off with C3 & DAS? If so please give me a small guide as to how?
2. If not what is the resistance setting for the wire, IE can I solder a resistor or 2 into the signal wire and trick it?
3. If all of the above not possible, I guess its an emulator off fleabay?
Thanks in advance guys 049
RE: ML B1315 airbag fault - art_arev - 11-03-2016
Have you thought of what will happen if he has an accident & there is a passenger with him?
RE: ML B1315 airbag fault - laz79 - 11-03-2016
he doesnt care, plus with emulator the a/bag goes off with or without passenger
RE: ML B1315 airbag fault - efka - 11-03-2016
He does not care..... What about you? Money does not stink?
Please either help, or move on. thanks. Dont forget most occupancy senors are for car insurance companies so they dont have to pay for paassenger airbags when nobody is sat in it. Emulators etc mean it will fire with no passenger
RE: ML B1315 airbag fault - sunce - 11-03-2016
you can turn it off with das, you just have to cut 3 wires going to sensor under seat
i dont remember exactly procedure but you must find it, go to airbag>programing find seat occup. sensor and disable it
Thanks. its got 3 wires, so maybe ill unplug and recode with das somehow.
Failing that, can the airbag ecu be read and writted with fault code removed? If so anyone know what chip to read?
RE: ML B1315 airbag fault - Raints - 11-03-2016
Ia m using a cheap emulators. You cant put any resistors cos it sends some coding string to airbag ecu.
If you have das whit no password in special function, you can disable seat mat.
If you disable it you must disconnect sensor to.
SolvedBig Grin able to program via das. +1 rep given!
