W204 SCN programming Audio unit - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W204 SCN programming Audio unit (/Thread-W204-SCN-programming-Audio-unit) |
W204 SCN programming Audio unit - Credoline - 11-03-2016 Hello members. I have need in W204 2008 year to make work an Audio unit. Original is replaced with used one which is the same as old one except is from 2012 year and have different in configuration. Problem is what this new unit is coded to have MOST and Sound system activated. And old one have not, and with new one i do not have sound at all. In Xentry Adaptation menu is possible to do SCN coding but its Online. Mercedes software for this car work in Xentry only. I have installed 12/2014. What i need to do and to have to be this possible for me ? How to make SCN offline possible ? Or it is any other way to make this unit to work with sound ? Any advice what to do ? Thank you RE: W204 SCN programming Audio unit - MegaCar - 11-03-2016 (11-03-2016, 09:50 PM)Credoline Wrote: Hello members. I have need in W204 2008 year to make work an Audio unit. Original is replaced with used one which is the same as old one except is from 2012 year and have different in configuration. Problem is what this new unit is coded to have MOST and Sound system activated. And old one have not, and with new one i do not have sound at all. In Xentry Adaptation menu is possible to do SCN coding but its Online. Mercedes software for this car work in Xentry only. I have installed 12/2014. What i need to do and to have to be this possible for me ? Hello, Do you have Vediamo? I can help you. PM me. RE: W204 SCN programming Audio unit - charles.soori - 11-03-2016 Maybe engineering menu in head unit can disable most. RE: W204 SCN programming Audio unit - Credoline - 11-04-2016 In head unit its not possible to change anything what i can not change from menu on audio unit buttons. RE: W204 SCN programming Audio unit - MegaCar - 11-04-2016 Sir, Can you connect bluetooth? Do you have vediamo? If you have vediamo i can help you by tv. Thanks RE: W204 SCN programming Audio unit - charles.soori - 11-04-2016 (11-04-2016, 10:22 AM)Credoline Wrote: In head unit its not possible to change anything what i can not change from menu on audio unit buttons. I just tried it and It works. Hold hang up button + # +1 then go into hw setting, tgw parameter and disable most. Then do system reset |
