SD Connect & 09.2016 Problem Firmware & DAS Error - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: SD Connect & 09.2016 Problem Firmware & DAS Error (/Thread-SD-Connect-09-2016-Problem-Firmware-DAS-Error) |
SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-08-2016 hopefully someone can help because I've been trying all day and can't solve this, I installed Xentry WIS StarFinder [09.2016] Win7 x64 Acronis Image Torrent from this site on a dell d630 set it all up with my SD connect all seems to be connected correctly unitl I open Xentry it instantly pops up: VCI Firmware Update VCI_TL_OPERATING_CODE firmware is being loaded this is every time I open Xentry When I open DAS and try and Diagnose something I get the error: Fault (1.2) 2.503.13012 Initialization of diagnosis multiplexer failed Can't find any info on that error code anywhere? Really need to get it working tonight if possible RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Yudi - 11-08-2016 Hello, You need Insert Battery Type AA 6 Pcs at your mux. then do diagnose car again, that will automatic firmware. and your xentry will not appear that loading again at next time. Regards, RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Anturage - 11-08-2016 Which firmware SD Connect has now? RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-08-2016 Wow that was fast thanks man I'm off back out into the cold to try it now. DAS error caused by the firmware as well do you think? Ok put some batteries in and went back out, connect still does auto detect then firmware update flashed up for about 5 seconds? when the batteries were in as soon as I plugged it in to the vehicle it said Insert Batteries again with !! marks? I've attached pictures of the serial and firmware etc - ![]() ![]() ![]() ![]()
RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-08-2016 Do I need to update all the softwares shown in the picture? I clicked start on the top one clearceflashdisc.zip it said it had updated but still shows in the updates? RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Marcos - 11-08-2016 (11-08-2016, 02:10 AM)crashndash Wrote: Do I need to update all the softwares shown in the picture? I clicked start on the top one clearceflashdisc.zip it said it had updated but still shows in the updates? Better STOP updating EVERYTHING once it is not too late to brick your unit. You already have the latest firmware on it! RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Anturage - 11-08-2016 Firmware is up to date RE: SD Connect & 09.2016 Problem Firmware & DAS Error - crashndash - 11-08-2016 Ok so don't update anything from the list, why the automatic update every time I try to use Xentry - VCI Firmware Update VCI_TL_OPERATING_CODE firmware is being loaded RE: SD Connect & 09.2016 Problem Firmware & DAS Error - Anturage - 11-08-2016 This is diagnostic session firmware loaded. It may be different in different session. Depend on vehicle and ecu. Probably SDConnect dead if it fails while downloading. Launch selftest. |
