1999 s600 issue with trunk want open - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: 1999 s600 issue with trunk want open (/Thread-1999-s600-issue-with-trunk-want-open) Pages:
1999 s600 issue with trunk want open - cps01 - 11-11-2016 Thank everyone for helping out on this I have a 99 s600 w140 body that the key want open the trunk and now broke the key trying so waiting to get a new key made and keep on trying So far i have put tried using the trunk release switch and the central locking switch with no results , the trunk release on the FOB key also is not working as well Tried opening the back where the First Aid kit is and not able to do anything with that. Any help would be appreciated Thank you in advance RE: 1999 s600 issue with trunk want open - mtechno - 11-11-2016 Its difficult to help without scanning systems for faults and live data values and post your results you may have just broken wires at hinge and key lock is just seized from lack of use but without seeing the car or scan results we can only guess! RE: 1999 s600 issue with trunk want open - cps01 - 11-11-2016 Thank you for the update in the next few days i will get a key and see if any error codes , The car was driving fine just that the trunk does not open, and it looks like the central lock is also not working as well RE: 1999 s600 issue with trunk want open - efka - 11-11-2016 If it helps.... under rear seat.Air Pump module....... (cracked hose inside) RE: 1999 s600 issue with trunk want open - cps01 - 12-01-2016 still waiting for Key from Mercedes, they gave me a valet as the remote is on backorder However cannot open trunk and PSE pump not working Anyone know of a way to get open the trunk I was also told seeing this is a 99 if i get the PSE pump fixed i will still need to activate / program the new PSE pump if i do that Any help in opening this trunk would be appreciated as far as the code , evrything looks fine , no error code however just using a standart reader RE: 1999 s600 issue with trunk want open - Rocinante - 12-02-2016 Is this a W140 or a W220? There is an extensive thread about getting into a W220 trunk.. RE: 1999 s600 issue with trunk want open - cps01 - 12-02-2016 its a w140 body RE: 1999 s600 issue with trunk want open - efka - 12-02-2016 did you try simply disconnect, reconnect PSE? RE: 1999 s600 issue with trunk want open - Rennbenz - 12-02-2016 And check the vacuum lines for continuity / tightness ...
