03 SL500 ecu DAS connection problem - Printable Version
+---- Thread: 03 SL500 ecu DAS connection problem (/Thread-03-SL500-ecu-DAS-connection-problem)
03 SL500 ecu DAS connection problem - marvelouzone - 11-14-2016
Trying to diagnose a problem on a friends 2003 sl500, the problem is no scanner including star/das will connect to it, with das, I can read every other control unit, except me-sfi 2.8 All ecu fuses(29,30) and relay k check out good, I have power at ecu pins.
Problem with the car is no start. there's no ignition signal to coil packs,fuel pump only comes on for a quick second when ignition comes on, not enough to build any fuel pressure. Car cranks, but thats it.
what's the best way to check CAN wires at ecu, I'm assuming this could be an issue with communication with das and other scanners. and is there a wakeup wire for ecu besides CAN? Has anyone seen an ecu go bad to the extent that there is no type of communication or signal from it?
if ECU does have to be replaced what is the correct procedure? I see units listed with the key module and key, do these have to be replaced together? I also see units listed that says used with vin cleared.
RE: 03 SL500 ecu DAS connection problem - KriyenKPp - 11-14-2016
im busy trying to cet a 2001 s500 started and found the plugs on ecu is green. water ingress, open plugs and check
RE: 03 SL500 ecu DAS connection problem - marvelouzone - 11-14-2016
(11-14-2016, 09:59 AM)KriyenKPp Wrote: im busy trying to cet a 2001 s500 started and found the plugs on ecu is green. water ingress, open plugs and check
thanks will check that
