Installing Xentry/DAS from ground up - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Installing Xentry/DAS from ground up (/Thread-Installing-Xentry-DAS-from-ground-up) Pages:
Installing Xentry/DAS from ground up - Freebird - 11-14-2016 Hi guys. A couple of days ago my Xentry installation failed, probably due to a faulty harddrive. Therefore I'll have to start over to get my system up and running again. This time however I'd like to try to install the software from the ground up. - I'm first of all interested in using this on a bit older cars, W202, W210, W163, W463 etc. - I've got a Dell D630 computer - I've got a chinese knock off C4 mux - I'd preferebly like to use Windows 10 og Windows 7, VMWare is also a possibility Is this at all possible or do I have to use Windows XP. Where do I start, are there any complete guides available? Thanks in advance.
RE: Installing Xentry/DAS from ground up - alladdin205 - 11-14-2016 http://mhhauto.com/Thread-Xentry-OpenShell-XDOS-09-10-2016-16-9-5-1st-Web-Release http://mhhauto.com/Thread-Mercedes-DAS-Xentry-Last-Version-12-2015-1-2-2016-1st-Web-Release http://mhhauto.com/Thread-DAS-Xentry-Multi-Solution-2014 http://mhhauto.com/Thread-XDOS-OpenShell-WIN7-x86-Installation-Solutions And a lot to READ... And forgot this colection..all you need http://mhhauto.com/Thread-XENTRY-Diagnostics-OpenShell-PassThru-Kit-old-STAR-DIAGNOSIS-SOLUTIONS-by-DieTRih RE: Installing Xentry/DAS from ground up - Freebird - 11-14-2016 (11-14-2016, 02:27 PM)alladdin205 Wrote: http://mhhauto.com/Thread-Xentry-OpenShell-XDOS-09-10-2016-16-9-5-1st-Web-Release Thank you! I'll have a look at those links and try to read up on what I can find of information.
RE: Installing Xentry/DAS from ground up - Mackhack - 11-16-2016 Go with Win 7 and 12/2015. No need for any 2016 version. It's an easy install. No need for VMware. It's slow as hell. Minimum 160 GB HDD, preferably 250 GB. SSD for extra speed. RE: Installing Xentry/DAS from ground up - Freebird - 11-20-2016 Thanks a lot guys. I've finally got it up and running, the only thing missing is a key for Xentry DAS. If someone could generate keys for me I'd be very grateful. ![]() Xentry 09.2016 System number: 000000 Hwid: 4FB93A3CB110 App ID: 252 Lan ID: 080002E963C0 RE: Installing Xentry/DAS from ground up - Mackhack - 11-20-2016 (11-20-2016, 04:05 AM)Freebird Wrote: Thanks a lot guys. I've finally got it up and running, the only thing missing is a key for Xentry DAS. If someone could generate keys for me I'd be very grateful. Xentry: D9BTNTNE2DBKDQLY6VWXJRMZ9RJWTRMRYMBMM5BEHC73KF558T3PYWMUU72QMMNWF8XC7CVXYPB63LBZ6AZNPU6AX9F4AU7FJJAT3W9MVC9793YJBUZQTLGFHBJEYL5N5A DAS: *1rrt0ztk220pqznbv4xvhhtz3jgvtgoohjdgphl0vsce2 RE: Installing Xentry/DAS from ground up - Freebird - 11-20-2016 (11-20-2016, 04:14 AM)Mackhack Wrote:Thanks a lot Mackhack. Those worked perfectly.(11-20-2016, 04:05 AM)Freebird Wrote: Thanks a lot guys. I've finally got it up and running, the only thing missing is a key for Xentry DAS. If someone could generate keys for me I'd be very grateful. I've however come across another error. When connection to the car and trying to run diagnosis I get error code "Fault (1.10)-99.830.0". Any suggestion as to what I should do to fix this? (Chinese C4 mux) Thanks. Freebird RE: Installing Xentry/DAS from ground up - Mackhack - 11-20-2016 Fix is available on MHH. Has nothing to do with C4. RE: Installing Xentry/DAS from ground up - Freebird - 11-20-2016 I've spent quite some time trying to find a viable solution to this error error "Fault (1.10)-99.830.0". As far as I understand it is also known as Cal 830. However, I can't seem to find any solution that is works. Would someone be so kind as to point me in the right direction? |
