W211 ACC no heat problem Solved - Printable Version
+---- Thread: W211 ACC no heat problem Solved (/Thread-W211-ACC-no-heat-problem-Solved)
W211 ACC no heat problem Solved - Raints - 11-15-2016
Hi i have a problem whit this car,
No fault codes in ACC, but no heat. I replaced heat exchanger shutoff motor.
Its not helped me.
When i actuate left or right blend actuator motor i got a heat, but right away when i log out its stopped produce heat.
No internal fault no mechanical fault etc.
Looks like ACC module giving wrong data.
Can somebody point me what to do?
RE: W211 ACC no heat problem - mersum1es - 11-15-2016
(11-15-2016, 07:23 PM)Raints Wrote: Hi i have a problem whit this car,
Its not helped me.
What are readings of all temp sensors?
RE: W211 ACC no heat problem - Raints - 11-16-2016
I checked all readings normal, i will double check tommorow?.
RE: W211 ACC no heat problem - Rocinante - 11-16-2016
Please post a complete short test as well as check the outside temp sensor reading in the instrument cluster..
Here are all readings.
RE: W211 ACC no heat problem - mainio - 11-16-2016
Front Sam driver chip. See instructions from YouTube.
Ok i saw this instruction.
But i get heat when i actuate left or right blend motor.
RE: W211 ACC no heat problem - Raints - 11-17-2016
One thing i dont understand, why i get different AMB temp readings in ACC and IC?
ACC is 5 degrees and IC is 13.
I checked that heat exchanger shut off is working correctly.Heater core is warm enough.
ACC should get same readings from IC over can?
Thanks in advance!
