Help vito 2012 - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: Help vito 2012 (/Thread-Help-vito-2012) |
Help vito 2012 - zaid - 11-27-2016 Hello friend I have problem with MB vito cdi 639 2012 , it's leak power , i went to workshop he tell me to clean catalyst , after that everything goes ok but its white smoking now Help what can i do to solve this problem thanks in advance RE: Help vito 2012 - mb_port - 11-27-2016 have you dpf? i think full and regenerate RE: Help vito 2012 - igormeha - 11-27-2016 I think you need to make a diagnosis SD. Then only we can recommend a solution. RE: Help vito 2012 - valiuskli - 11-27-2016 what is mileage? I think the problem is jaming injector and too much fuel in cilinder... check oil level maybe is more than specified RE: Help vito 2012 - zaid - 12-01-2016 (11-27-2016, 09:11 AM)mb_port Wrote: have you dpf? i think full and regenerate Yes i clean it , after that problem Occurred thanks (11-27-2016, 01:56 PM)igormeha Wrote: I think you need to make a diagnosis SD. Then only we can recommend a solution. I made SD diagnosis with no faults thanks (11-27-2016, 06:01 PM)valiuskli Wrote: what is mileage? I think the problem is jaming injector and too much fuel in cilinder... check oil level maybe is more than specified mileage is 484357 , oil level is ok i test and see everything is ok . thanks |
