W168 ECU swap help needed - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W168 ECU swap help needed (/Thread-W168-ECU-swap-help-needed) |
W168 ECU swap help needed - HG-Automotive - 11-28-2016 Dear friends, is it possible to switch a eeprom from one ecu to another ecu on a w168 a140 ecu this is the ecu combination with Mas air flow sensor integrated kind regards HG RE: W168 ECU swap help needed - mb_port - 11-28-2016 a140 msm immo on flashchip,you can swap RE: W168 ECU swap help needed - efka - 11-28-2016 NO its not possible. RE: W168 ECU swap help needed - smayer - 11-29-2016 Yes it´s possible, you can swap flash 29f200 RE: W168 ECU swap help needed - efka - 11-29-2016 Question was about eprom. Immo data is in Flash. |
