W211 transmission - Printable Version +- MHH AUTO (https://mhhauto.com) +-- Forum: MHH AUTO FORUMS. (https://mhhauto.com/Forum-MHH-AUTO-FORUMS) +--- Forum: General Automotive Help & Discussions. (https://mhhauto.com/Forum-General-Automotive-Help-Discussions) +---- Forum: Daimler Group Mercedes-Benz, Smart Discussions. (https://mhhauto.com/Forum-Daimler-Group-Mercedes-Benz-Smart-Discussions) +---- Thread: W211 transmission (/Thread-W211-transmission) |
W211 transmission - amr_200 - 11-29-2016 Hi all mhhauto.com members I have installed 722.6 transmission In w211 model 2006 But I have a small problem that I cannot see the selections (P.RND) in the instrument cluster How can I solve that Thank you all RE: W211 transmission - Jeff_Spicoli - 11-29-2016 Rebuilt Tranny? Used? Was used one out of same model and year? 722.6 only needs to be adapted. Any codes? Is scantool seeing it being shifted? RE: W211 transmission - Rocinante - 11-29-2016 PRND in cluster comes from the signal in the shifter.. RE: W211 transmission - amr_200 - 11-29-2016 Plz more explain . How can I discover this problem . Plz feed me with more information RE: W211 transmission - kin1830 - 11-29-2016 check the shiftier and try to communicate with it by das RE: W211 transmission - amr_200 - 11-30-2016 I have solved this problem by changing the transmission type to automatic transmission (present) both sides the instrument cluster (IC) and gateway control module (CGW) thankx to all for help |
